Battery Problem, need help ASAP (1 Viewer)
Ian Paul
45
13
I have just finished my conversion but volt meter gives a reading of 9v if I connect the dometic Fridge, is this normal ? please comment I have made a film to explain...
JJ
Mágica
May 1, 2008
19,258
48,031
Burstner Privilege T
over 50 years
Are you running a compressor fridge?
If you have a "normal" gas/mains/12volt fridge, it does take a huge wack of electric on 12 volts... I think around 8 amps +...
I am not an expert by any means, but think the voltage drop is due to this considerable load being taken out of the battery...
JJ :cool:
andy63
4,672
15,017
south shields
since 1990
Hi.. i suspect its telling you your battery has no capacity...
The voltage you are seeing is the solar panel voltage...
As soon as you load the system with the fridge which is most probably around 120 or more watts the load pulls the battery voltage down and a 100 w panel will not supply that sort of load..
Andy
Pete5996
767
1,868
Deep in the Lot
Autotrail Cheyenne
Since 2002
Forgive me for mentioning it but starting three threads simultaneously on the same question can only lead to repetition and confusion...:)
As JJ says, if it's a standard 3-way fridge, running it on 12V from a battery doesn't work - the 12V operation is designed to be used from the vehicle alternator when the engine is running.
Jul 29, 2013
9,071
18,508
Salisbury
Hymer B678DL A class
Your solar is being used to run fridge but no enough capacity therefore draining your battery as well(y)
Jul 29, 2013
9,071
18,508
Salisbury
We have our solar working the fridge but through the Schaudt control panel.(y) It will supply power when available.
53,417
149,916
Either a duff battery or is there a problem with your wiring or solar regulator and the battery is not getting charged.
What happens it you charge the battery up on mains then with either the solar panels covered or disconected or in the dark. Does the same thing happen when you plug the fridge in? If so looks like the battery has had it.
17,630
43,253
looks like your battery isnt charged, what you see before plugging in is the solar charging voltage. this is dragged straight down to actual battery voltage with the load applied
Sep 3, 2012
7,551
26,056
Cheshire
C Class Elddis 175
8+ years
Try plugging something in that takes less power than a fridge-if the voltage falls to the same then check your battery out
Cleve
789
2,333
France
Hymer 654
Correct me if I am wrong (I am sure you will) but my understanding is that the 12v supply is from and when the engine is running and all that it does is to maintain the level as best it can that had previously been achieved while connected to the mains (EHU) or running off the gas.
My experience is that it is inefficient and will be struggling after a couple of hours. Though of course that could be just me.
If you have asked the question elsewhere I hope I am not repeating what others have said.
Oct 2, 2008
4,469
7,955
Salopia
Duro 6x6 Overlander
since 1968
@TheBig1 has pretty much hit the nail on the head , the solar (100w) cant supply enough to power the fridge , and the battery is flat (knackered) . What happens if you start your engine , if you have a good b2b charger set up . This should be enough to maintain a higher voltage in system .
Feb 9, 2008
8,945
18,699
Corby, Northants
Coach Built
When you put a load on your battery, the reading will drop. It's virtually impossible to measure the battery state when a load is placed on it. The 14.4 V reading you have is a result of the power coming from your solar panel to your 125 AH leisure battery. The size of the load you are placing on the battery when you plug that 12V fridge socket is almost certainly the issue here. Can you work out how many amps it's pulling ? Finally, I would suggest disconnecting the power from the solar panel to your leisure battery and apply a small known load to the battery and see how it behaves. If it drops right down quickly it could be an indication of little to no capacity left in the battery and if so it may need replaced. (i would try and recover it first with a good quality battery charger). You don't say if it's Lead Acid, AGM or Gel. Gel can be heavily discharged without causing damage to the battery. If your battery is goosed and your going to replace it and you still want to run the fridge from your leisure batteries I would suggest getting more solar power (as much as you can) and possibly another leisure battery depending on the type you have. Remember to make sure your on board charger can cope with the extra capacity.
53,417
149,916
@Jim, he has 3 threads running on this any chance of combing or deleting a couple, mighty confussing.
You need a voltmeter across the battery in case there is a cable fault to your socket.
Feb 16, 2013
19,731
52,010
uttoxeter
ambulance conversion
50 years
is this a three way fridge, if so it shouldnt be used on 12 volt if the engine is not running
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I would suggest any battery that reads only 9v has lost a cell and is knackerd - no matter what it's connected to.
Ian Paul
Ian Paul
45
13
Thanks for the replies, what size wire is recommended to use ? I have a new 125 amph leisure battery fro Halfords.
53,417
149,916
Can you have voltage only going into a battery. Are you winding me up again !
Possible if the regulator is duff or there is a wiring fault and the socket is only getting fed from the solar.
Would I wind you up Phil: Brilliant scheme you keep recommending what was it called, NCC Verified Battery Scheme.:rofl:
Ian Paul
Ian Paul
45
13
AS an update I replaced the thin wire and replaced with 240v mains wire, with just the battery connected with 12.6v as shown on the control panel, and just connected the battery to the fridge it then went down to only 10.4v, all solar including its controller where not connected. I tried to see what would happen if the solar was re connected in fact the solar controller is completely dead, Ive only used it for 12 hours at most.
