Zilevets
I would expect BOTH to be hot if it was overcharging Lenny.Keep a careful eye on the other battery it could be a faulty charger cooking the batteries.
Yes, you can. The charger should be able to power the hab electrics providing you aren't using lots of 12v stuff.If we just disconnect both batteries can we just hook up to lekky till Monday and then get new batteries fitted then or not if not we need to head home.
Liz
4 years ago when we bought it from dealerHow long ago was second (top) battery fitted ?
Oh just told Steve I’m not feeling good but will sit out in rain hopefully that will do the trickIf you disconnect both but ensure the terminals can't short it should work on EHU, using the battery charger as a supply
Get plenty of fresh air to clear out the poisoning from your system. If you have a headache seek medical advice
Possible one may cook before the other just need to keep an eye on it just in case.I would expect BOTH to be hot if it was overcharging Lenny.
Will change both if we can find someone around here who can do it quick that way I’m not worrying does anyone know a mobile fitter around Ingleton if not will head home and see if caravan Dan can do them.Possible one may cook before the other just need to keep an eye on it just in case.
Off & On, if its a fairly old EBL best left alone, they tend to get a bit dodgy when old, turn it off and it won't turn on again.For all you teckies on here on the shaults box I’ve got a switch on front up says Ein and bottom says Aus just curious what that is.
Liz
Thanks for your replies I’ve just realised we’ve been sat in it for 8 hours had gas on and telly and been in danger!! Spent most of the day telling Steve his feet smelt! Van doors all open realised we’ve got RAC cover and leisure batteries are included so have given them a call hopefully they know what they are doing
Liz
technically it's IN & OUT I thoughtOff & On, if its a fairly old EBL best left alone, they tend to get a bit dodgy when old, turn it off and it won't turn on again.
It turns off a relay disconnecting the battery from the 12v outputs, the charger still functions.Thankfully I stopped Steve from doing that as wasn’t sure if that would isolate the battery from ehu.
