My sergeant unit is showing a 0.8amp draw when in storage would I benefit from switching it off when not in use . I have a solar panel but at this time of year 100w solar if not keeping up.PS I also have 2 110amp batteries
First off, have you calibrated the read out ?My sergeant unit is showing a 0.8amp draw when in storage would I benefit from switching it off when not in use . I have a solar panel but at this time of year 100w solar if not keeping up.PS I also have 2 110amp batteries
What van, year have you ?It’s a Sargent ec450 and a good victron controler
.8 amps over 24 hours is 0.8 x 24 = 19 amp-hours. I don't think you'll get anywhere near 19 amp-hours from a 110 watt solar panel in one day in winter, particularly as it's horizontal and not angled to the sun. Ehu for 24 hours every month at least is a good option.Even in dull conditions a 110w solar panel should easily keep up with a .8 A draw.
Actually very true. I did not do the math before using the keyboard.. my bad !.8 amps over 24 hours is 0.8 x 24 = 19 amp-hours. I don't think you'll get anywhere near 19 amp-hours from a 110 watt solar panel in one day in winter, particularly as it's horizontal and not angled to the sun.
If that .8 amps is accurate then it will need EHU every week. As Jaws says, it may not be accurate and the panel might need calibrating.
Ok.. In that case I do not think you have an EM50 sub unit fittedSwift bessacarr 462 2014
Depends on what panel you have.. For most, select amps on the panel and press and hold the middle right button ( often has an arrow on it pointing left )Can you tell me how you recalibrate a Sargent panel please?
On the control panel ( usually over the door ? )I have the Sargent EC450 like this one. Which buttons do you mean?
my panel is the one like in the picture above from jo662 , I have plugged it in to mains for 48 hours then I will switch sergeant off and see how it goes , I can't leave on hook up all time as its not practical where it is parked up.Any update at all Lozsing ?
Well said Norman. ?? What is the foreign language the others are talking about? Amps, volts, recalibrating!!! ?? Just use it. ?It's no good leaving any vehicle standing all winter.
Take it out for a good run of at least 30 miles every couple of weeks minimum to heat the engine up properly polish up the brakes and anything else mechanical.
Otherwise not only the batteries suffer but anything that moves will start to corrode or seize up.
All vehicles are designed to move, not stand idle.
Might as well not bother..8 amps over 24 hours is 0.8 x 24 = 19 amp-hours. I don't think you'll get anywhere near 19 amp-hours from a 110 watt solar panel in one day in winter, particularly as it's horizontal and not angled to the sun. Ehu for 24 hours every month at least is a good option.
I didn't know that ! How does that work then if its switched off!I dont know whether its relevant to you, but an inverter will draw power even if switched off. I have fitted a battery isolation key switch to mine and turn it off in storage. Not a big drain, less than 0.5A but it all adds up in winter.
The same way your TV does..... Stand-by current.I didn't know that ! How does that work then if its switched off!
Thanks for that! Sometimes In cant see the wood for the trees! That would explain why my control panel is showing 0.8 Amp draw! Simples. I would just pull the inverter fuse if it ever became an issue.The same way your TV does..... Stand-by current.
Switching it off only turns off the 230v circuit, the 12v circuit is always on.
