Battery charging (1 Viewer)
Nov 5, 2017
178
267
Nouvelle Aquitaine France
Profile
Since 1980
When you are plugged in to ehu, plus solar panel connected, what should the battery reading be, is it possible to cook the battery? Mine is reading 14.1 is that ok? Cheers.
Oct 20, 2010
2,203
37,419
Burry Port South Wales
Since 2003
This is the current reading from my system, as you can see the Max battery volts is up at the 14.5, so you should be fine.
Ed
Lenny HB
50,273
138,855
On the coast in West Sussex
Hymer B678 DL
If it's permanently at 14.1v it's too high, some batteries are ok with Gels normally survive.
Most Motorhome chargers are 3 stage, bulk charge to 14.2-14.4v (14.8 for AGM), then an absorption phase at the same voltage for several hours then drop to a float of 13.6-13.8 v.
