Battery breather
plymouth
Sprinter
off and on 30 years
I have a sprinter campervan with a delta 110a leisure battery no vent tubes fitted but with a vent hole either end now does it require a vent tube in either end or just one end The battery is located within the van. TIA
It just needs a vent tube at one end. The other to be blanked. They come with two, so it can fit more vehicles.
My understaning is that just one side is ok to be vented outside as long as the other end has a stopper.
Have a closer look it may have both stoppers in place, remove one and vent the other.
If no stoppers then you can vent both if you want in case you have trouble finding a stopper.
Kits online for just a few £'s or try car accessory shops.
Thank you very much 👍
Don't buy genuine battery vent elbows and tube - horribly expensive. B&Q have a selection for little money
Went to the local breakers who had a quick look found a elbow here you are mdear no charge thank you very much. Result❤️❤️❤️❤️
