Two on Tour
- Sep 16, 2016
- 10,303
- 50,698
- Elddis Autoquest 175
- Since 2010
Advice please, I'm fitting a second 110Ah battery (both the same capacity from the same manufacturer) and wiring them in parallel as per the drawing with a fuse at each end of the positive line.
In addition I'm fitting a 1000 watt pure sine wave inverter and a 150 watt solar panel via a Victron BlueSolar 75/15 MPPT regulator. I plan to fit an isolator switch and a 100 amp fuse in the inverter 12 volt positive line and a 15 amp fuse in the solar panel positive line from the regulator to battery.
Now the questions, bearing in mind the normal draw from the habitation side plus the solar and inverter what are the thought regarding the values required for 2 fuses in the positive line joining the batteries and are the values I intend to use in the solar and inverter lines OK ?
