HarryHamsta
- Mar 25, 2019
- 27
- 6
- Coachbuild
- 4 years
Hi all,
My moho is a Laika Ecovip 6. Imported last year from Germany. I overhauled the 12v system as previously it was running on a single 70ah leisure battery and we do a lot of wild camping / so I need an inverter to power my laptop for work.
Last June I installed 2 x 140ah Bosch leisure batteries in parallel, a Victron charger controller connected to a 300w pv panel, a 1000w inverter, and a few other bits and bobs (USB plugs and the like). I rerouted the existing wiring from the engine bay (where original leisure batt was) to the rear, where both new leisure batteries located. Everything worked fine. I will admit I mistreated the batteries somewhat over autumn / winter as the nights drew in, and they discharged to 11.9v on a fairly regular basis. We have been in an airbnb in France since mid-December. When I drove back to the UK in January then a number of appliances stopped working. Using anything with a medium / high wattage (water pump, electric step) would result in lights completing blacking out. When I returned to France then I used a smart charger to recondition the batteries. Since then I spent this evening in the campervan and am still experiencing the same problem. Lights work but go out when turning on pump. Turn off the pump, lights are back but very dim. All the hallmarks of battery with no charge.
What is confusing me is that the voltage is still reading 12.5/12.6 when this is happening. This is from a multimeter on the battery terminals. The inverter still turns on when the lights have blacked out, although I haven't tried charging anything from it. AFAIK it doesn't have a low voltage cut-off like other inverters I have used.
I have a good practical understanding of 12v but my theory is lacking. Is it possible for a battery to be 'dead' but for it still to register a high voltage / fully charged? I'm happy to replace the batteries but I don't want to spend £200/300 on batteries only to find out this isn't the problem.
Any thoughts would be greatly appreciated.
Harry
Harry
