WynandJean
Can anyone help get the control panel into 'manufacturer mode'? It is the 2017 model and can only find instructions for older models.
Wyn
Wyn
Success! Thank you so much. It certainly is a fiddley business until you get the hang of it.Hi Wyn
My vehicle is the 79-6, I have Just been in van and after a number of go's managed to get into manufacturers settings as follows
with panel turned off
press and hold both scroll keys and the pump (tap) key for about 5 seconds
release scroll keys (whilst still holding pump key) and press the lights key
release all keys and you should see manufacturers settings on the screen
press enter key to enter manufacturers settings
please note it does take some patience as if any key press is slightly released at the wrong time it doesn't work, I also found after an unsuccessful attempt I always turned master on and then off again and waited till screen went dark (though not blank) before retrying. I have been told it should be the same even if power is on but haven't tried it.
Kev
