Bailey Alliance
Just looking
I am a newbie
Bailey Alliance 76-4t 2021 control panel is saying 100% full of fresh water when it’s empty, I can find anywhere to recalibrate in the settings menu or am I just missing something. Any help on this would be greatly appreciated.
I don't suppose it can be recalibrated. Certainly none of our vans have been. It's usually the sensor has failed or needs a clean. Occasionally, if you can get to the top of the tank and there is a removable screw cap you can reach in and a gentle clean of the sensor may solve the issue. You may also be able to see the sensor connectors; if so, just check nothing is shorting them. The sensors are not horribly expensive and are easy to change IF accessible. None of them are much cop, giving a guide rather than an accurate reading.
We have a Bailey 2023 which has a menu in the ‘water level’ to calibrate.
We go to ‘water level’ , press the BACK button to enter the calibration function. Tank needs to be empty. Press to confirm empty.
Then fill tank and do the same in the FULL function to register 100% water.
Easier to do than explain.
That is on our van with our control panel. Yours could well be different.
Jaymac If you go to page 3 of Motorhome Technical Articles , which is found in the downloads section of the forum menu , there is information regarding calibration that may help.
If you need more information about your control panel and its operation www.bcagroup.co.uk has it in its Resources section.
