Bailey 794-T - Awning useless! (1 Viewer)
May 14, 2018
331
430
Lincolnshire, UK
Autograph 794-T
Caravan owner moved on to Motorhome
Get on site, whizz out the cassette awning just before the heavens open. Ahh has I thought a nice dry space next to the van. Wrong! The rain just p**ses down the side of the van. No seal between the van and the awning!
How many more things are wrong with this MH?
Riverbankannie
10,529
61,520
Bristol
IH 630 RL PVC
I don’t think it’s a fault. The awning designed as a sun shade. You can get a Fiamma drip stop to channel water away if necessary. Be careful about leaving awning out in heavy rain it’s not designed for it. Always put a sideways slope on if any rain expected (one leg higher than other).
Rain often comes with wind so always use extra tie down straps.
Oct 29, 2008
5,068
5,949
West Yorkshire
PVC
since 2008
There is a seal but it doesn't come with the awning. It's an optional extra.
eddie
8,156
41,250
Taunton Somerset
RV
since 1989
You made the schoolboy error of not telling them that you would like to use it in the rain lol
MC 55 FUN
3,432
6,347
Rural South West Wales.
2015 Majestic 195
Since 20th Feb' 2016
Both our non Bailey Moho's have had an awning fitted & both have had a slight gap between van body & awning case resulting in a slight drip down the side of the van when it rains, 90% + of the floor space the awning covers remains dry & usable.
That said we use it as a sun shade & not an umbrella.
Lenny HB
53,417
149,914
On the coast in West Sussex
Hymer B678 DL
The seal is just to stop crud collecting in the gap. The awning has been fitted incorrectly it should be sealed to the body all the way along.
Lenny HB
53,417
149,914
Hymer B678 DL
Another incorrectly fitted one.
Lenny HB
53,417
149,914
Hymer B678 DL
After fitting it should have bead of Sika all along the top of the bracket. Stops any water running down also protects the bracket from water sitting on it.
I've never seen one fitted without it.
DuxDeluxe
14,658
72,763
Planet Zog
A woosh bang van
since 2008
Exactly what I did with my Pilote - the awning stood proud of the side due to the structure of the van so I simply bought 4 metres of Fiamma drip strip and slid it into the slot designed for the purpose. As @Riverbankannie says, it is really designed as a sunshade
DuxDeluxe
14,658
72,763
Planet Zog
A woosh bang van
since 2008
Impossible to fit the awning flush on a Pilote A Class, though. And quite a few other vans
Paul Wilkins
May 14, 2018
331
430
Lincolnshire, UK
Autograph 794-T
Of course it’s wall to wall sunshine here in the UK lol
Point taken, I need to condition my UK van for UK weather...
Apr 20, 2012
428
455
derbyshire
Camper van
1year 10 times
There is also a sponge type strip made for this which stops the rain dripping
Paul Wilkins
May 14, 2018
331
430
Lincolnshire, UK
Autograph 794-T
Had my dealer seal the gap between the van and the awning, however I’ve not had any rain to test the seal (1st world problems)
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If it is on the correct Fiamma supplied brackets there will be a 3mm gap. Fitting flat to the body is the lazy way that makes awning removal for repair a much more difficult job than necessary.
Lenny HB
53,417
149,914
Hymer B678 DL
On the thule a bracket the full length of the awning is fitted to the van and the awning hooks on to it .
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
You could be right but if that's the case my Thule has been fitted with Fiamma brackets. Which is obviously a possibility as it was installed before l bought the van :).
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Mines fitted on brackets about 3mm gap but it does also have a strip above which stops water entering via gap
Lenny HB
53,417
149,914
Hymer B678 DL
The fitting depends on the van on Hymers the the bracket is shaped to fit around the roor/body joint.
