Paul and Kate
This is how a change the outside TV connection so I can plug into an onsite aerial.
Here you go
First you need 2 of these
Screw one on the outside aerial connection. You will need to remove this each time as theflap will not close with it in place.
The second one you will screw into the TVsplitter box in the wardrobe on our 75-2. Youwill need to unscrew the roof top aerial then screw fitting into the block.
Now unscrew TV 3 output.
So in the wardrobe you will have the roof aerialdisconnected (white cable) and TV 3 out (blackcable).
Now you need two of these
Screw one into the white roof cable and one into the black cable.
So if you want to use the roof aerial you plugthe white lead into the aerial block if you are using onsite aerial at a bollard you unplug the white lead and plug in the black lead,screw thefirst fitting into the outside aerial connector and run an aerial extention which should be male to male connection from the bollard tothe van and retune the TV.
Hope this is clear enough I will post photos of the actual setup at the weekend
Here you go
