Bailey 625 Thetford ussue (1 Viewer)
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Anyone know where the fuse is to check why flush button not working
We’ve check main fuse board but thought there was one in the cassette compartment but can’t find it?
lunarman
2,156
2,451
South Glos
since 1994
The fuse is in the cassette compartment.
Sorry should have read the last line. What Thetford model is it.
lunarman
2,156
2,451
South Glos
since 1994
There are several you tube videos on the repair of the Thetford pump.
If you have the 250/260 model there should be a 3 amp fuse in the back of the cassette compartment.
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Thanks for reply
It’s the C262 CWE Thetford, can’t see where there’s a fuse in the compartment, no illustration in book. Thetford not open to ask
lunarman
2,156
2,451
South Glos
since 1994
Bailey 15 At the back of the cassette compartment is there a cover held by 2 screws it may be under there with the reed micro switch pcb
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
No fuse ?
Could there just be one fuse then in main circuit board ?
Perhaps pump gone
lunarman
2,156
2,451
South Glos
since 1994
Bailey 15 The bailey approach service manual page 17 shows that the toilet shares the same fuse as the water pump. So if there is water coming from the taps then the fuse must be ok.
  • approach service manual.pdf
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Ah we thought that thanks
It’s really looking like the pump then du think
Feb 17, 2017
459
1,922
Herefordshire
A Bit
I thought the advance used a separate pump, be careful when reading the manual as if it is the same as mine it refers to both the Advance and the Autograph models not saying it isn't the same but I do know the Autograph (that's what I got) uses the same pump and draws water from main tank for both taps and toilet flush whereas the Advance model my sister has got has 2 tanks and 2 pumps one for taps etc and one for the toilet flush system, I will take a look in my manual when I get a chance (probably tomorrow) and see what I can find out, unfortunately my sisters Advance is in storage and the owner has locked the storage site down and not allowing any access.
Dec 12, 2010
5,410
21,560
Cumbria
since 2011
Check this thread for some pointers. We sorted my pal's Thetford non flush in his Autograph by changing the flush pushbutton circuit board, a common fault apparently.
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Great replies as always
Hoping to work on it Sunday
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
:swear: Found another problem !!!!
Shower leaking into van!!
Checked all tray don’t think it’s that but think it’s waste plug pipes.
Right—— how do we get at them, looked through all manuals, nothing ! We just think something had come off because one drainer is a lot firmer that the other
All ideas greatly appreciated
lunarman
2,156
2,451
South Glos
since 1994
On my 740 the pipes come out through the floor directly under the plug holes. Look under the van you should be able to see them and the traps. They cannot leak into the van on mine.
Is it a water leak from the shower mixer tap or the pipes to it as these could leak under the tray.
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Well we have 2 plug holes in our tray and we have put a rubber plug in the one we think the problem is and we have stopped the leak. This makes us think it is the pipes come separated on that plug.
We cannot atm see where we can get at these waste from underneath. What if we wanted to replace the waste? Don’t know how we get at it
MisterB
5,870
13,146
Essex
Adria 670 SLT
is it worth contacting Bailey themselves if they are open?
