B2B question please (1 Viewer)
Feb 22, 2011
9,749
20,074
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I have been thinking of fitting a battery 2 battery charger for greater off grid camping opportunities.
The alternator seems to put about 30 amps into the leisure batteries but only for a short period so not really much use.
Therefore I thought about fitting this unit ...
Victron Energy Orion-Tr Smart 12/12-Volt 30 amp 360-Watt DC-DC Charger, Isolated (Bluetooth)
Current setup is :-
2003 Hymer B544 A Class (Ducato x244)
EBL99
2 x 90 A/h Exide Gel batteries (one under each ISRI cab seat) age unknown but could be 10 years old. Seem to be performing ok
200 watts solar with a Votronic MPPT 250 Duo 20A MPPT Dual-Solar Charge Regulator 12V
My questions are -
Will this Victron unit do what I require and complement my current setup without issue ?
Can it be fitted next to the battery under one of the ISRI seats, assuming there is room for it ? I've never taken the seat off before so unsure how much space there is.
Is there an existing route to run the cables from under the seat through the bulkhead and to the cab battery ?
I'd like to fit it myself if possible as it seems straight forward, just four connections.
Thanks in advance
Sep 23, 2013
2,583
8,710
Lincs
Globecar Campscout
It would be unusual (but not unknown) for the 12v habitation wiring to be completely isolated from the vehicle chassis. Unless it is, there is no benefit to having the isolated rather than the non-isolated version. It is more common to use the isolated version on boats.
If your existing wiring is capable of handling 30 amps, not just for the few minutes after start up but continuously, I would think you could use that. Disconnect the +ve input cable from the starter battery at the rear of the EBL99 & connect it to the input of the Orion, then connect the +ve output from the Orion to the EBL99. Connect the -ve of the Orion to the common neutral. See the wiring diagram in the Orion manual - you are effectively using the battery connections on the rear of the EBL as the connections to the two batteries as shown in that wiring diagram.
Apr 27, 2016
6,848
7,940
Manchester
A class Hymer
Since the 80s
In most motorhomes, the alternator negative is connected to the chassis, and so is the starter battery negative. In the EBL, the starter battery positive and leisure battery positive are connected by a relay when the engine is running. The leisure battery negative is required to be connected to the chassis to fit in with all this. A non-isolated B2B would be most suitable for this. If you've already acquired an isolated type, then it is usable, just connect the negatives together.
The existing wiring probably has two 50A fuses, one near the starter battery and one near the leisure battery. The wiring is able to handle up to 50A. Because of that there's no need to run a wire through the bulkhead, you can use the existing starter battery wire as TheCaller described.
Be careful of the colour coding of those three connections at the back of the EBL. On mine it is: negative = brown, starter positive = red, leisure positive = black.
Jan 8, 2013
8,487
11,521
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Have a look at the Sterling versions.
It shows you the wiring diagrams and where
the output negatives go.
I've been happy with my one.
Jun 30, 2011
7,227
20,055
Barnard Castle, UK
Concorde Concerto
Are they effective with gel batteries, is there a gel setting?
Al n Val
2,264
5,611
West Yorkshire occasionally
Rapido i1090 Distinc
since 2018
I’ve got the Victron 12/12/30 and can say it’s superb, it does exactly what you bought it for and does it without any fuss.
Using the Victron app I can actually see what’s happening whilst driving along 👍
Go for it and i’m pretty sure you won’t regret it, also when you swap vans take it to the next one.
Al đź‘Ť
Figaro
Feb 22, 2011
9,749
20,074
Hymer B544 A Class
Since 2015
TheCaller autorouter
Just for the avoidence of any doubt, the connections can be made to the terminals on the bottom of the ELB 99 ?
With suitable breaker fuses of course.
2,583
8,710
Lincs
Globecar Campscout
Yes. What is happening at the moment is that terminal 3 is being fed with what the alternator thinks the starter battery needs, albeit with the load put on it by the EBL.
When you insert the Orion into that feed to terminal 3, you ensure that the feed into the EBL is a proper 3 stage charger feed, similar to what you would get from a 30A mains charger.
Feb 21, 2016
4,912
29,334
Uk
C class
Since 2017
Cripey cripes!!!!! I reckon anyone who understands all this stuff is a genius!:LOL:(y)
Where did you learn it….school,college,work,internet,mate next door,books?? Amazing.
Oct 9, 2019
4,936
17,207
Todmorden
Van conversion
FUNSTER in a PVC
Take a look at Sterling B2Bs no faults found with mine for over 2 years.
Figaro
Feb 22, 2011
9,749
20,074
Hymer B544 A Class
Since 2015
I had a look at sterling but they seem to be more expensive.
I can get the victron one for 199 pounds
Figaro
Feb 22, 2011
9,749
20,074
Hymer B544 A Class
Since 2015
With excellent help from autorouter and TheCaller , I've fitted the victron B2B this afternoon and everything looks to be working (y)
I'm just unsure of user settings ???
I've got gel batteries so set it to Gel Victron deep discharge (1) but there were options for 2 & 3 ?
Input voltage lock out - what values should I use ?
Engine shutdown detection - what values should I use ?
Many thanks for the help
davidroxburgh
283
425
West Sussex
Van Conversion
Since 2012
Votronic 1212-30 around ÂŁ170 from Road Pro net of Fun discount.
Apr 27, 2016
6,848
7,940
Manchester
A class Hymer
Since the 80s
If you are asking about Sterling B2Bs, yes there are flooded, gel and AGM settings, plus lithium. And provision for custom settings if if the preset values aren't what you want.
Figaro
Feb 22, 2011
9,749
20,074
Hymer B544 A Class
Since 2015
autorouter The Victron Connect app is asking if I have a smart alternator, I suspect not, but do you know ? 2003 x244 Ducato
I gather for gels bulk charge is 14.4 and absorbsion 13.7 volts, but I'm not sure what float voltage should be ?
I think I figured out the input voltage lock out and engine shutdown detection
Apr 27, 2016
6,848
7,940
Manchester
A class Hymer
Since the 80s
Smart alternators were only fitted on vehicles in the last couple of years, so yours will be a standard type.
There's no fixed voltage for the bulk charge stage, the charger sends out its maximum current (amps), and the volts slowly rises. When it hits the absorption voltage (14.4V) the charger sets the voltage to that value and proceeds with the absorption stage. The amps slowly falls from its maximum value. When the amps falls to a predefined limit, the charger decides the battery is fully charged, and switches to the float voltage (13.7V). For gel and some AGM batteries, usually the absorption stage is extended by a timed amount, a number of hours sometimes.
Figaro
Feb 22, 2011
9,749
20,074
Hymer B544 A Class
Since 2015
My Victron B2B seems to be working well, but the victron connect app will only show me volts going in to leisure batteries.
I've seen videos on YouTube that show the app displaying amps going in.
I've looked in all the settings and can't see an option for amps.
Anyone use the connect app that knows where I'm going wrong ?
Screen shot of the app.
Apr 27, 2016
6,848
7,940
Manchester
A class Hymer
Since the 80s
In bulk charge mode, the amps is simply the maximum value that it says on the tin. So maybe they think it's not worth having a separate line for it. Does it show amps when it reaches absorption mode?
Figaro
Feb 22, 2011
9,749
20,074
Hymer B544 A Class
Since 2015
I'm not sure, I'll check when next out in van.
The video I watched the app showed 20 amps going in from alternator when he started engine, after 15 seconds or so it jumped up to 50 amps as the victron kicked in.
Just wondering why I only see volts, doesn't matter I suppose.
Hoovie
1,249
1,689
Autotrail
Have you got a link to that video you mention?
I don't think current is shown by the VE.Connect App for the B2B but it sounds like maybe you are looking at a video of a BMV view via VE.Connect.
Jun 7, 2019
440
1,893
PVC
30+ years
Ive just fitted a Victron B2B too and was wondering the same thing. I'd be just as interested (for a while ast least) to know how much current is being fed to my LBs, as well the volts.
Figaro
Feb 22, 2011
9,749
20,074
Hymer B544 A Class
Since 2015
I think you may be correct about the battery monitor or lack of in my case being the difference, but I have fitted the same b2b as in the video.
It's John and Mandy, here's the link, the bit that shows amps is about 11:20
May 19, 2020
205
248
Knaus Sun Ti 650 MEG
Since 2020
No current shown with B2B app on Victron connect, the video above looks to be reading current from a Victron shunt, it is worth it imo keeping an eye on the output of the Victron because if its getting hot , it falls off markedly. This was the issue I had but a conductive mounting and a PC fan have brought the temperatures down to below 40C
Figaro
Feb 22, 2011
9,749
20,074
Hymer B544 A Class
Since 2015
Ok, a bit more research done, it seems like the B2B only gives voltage. The solar controller and battery monitor give much more info including amps.
If you open the app and click on the three lines top left, you can select Demo Library, from there you can select all victron products to see what info is provided.
B2B is basic info :confused:
Al n Val
2,264
5,611
since 2018
you need a shunt to see the current afaik, mine is the same as yours and voltage only shows
The current should be 30A at bulk charge
Al đź‘Ť
