We've been doing more and more off grid recently and fear with the bike recharging, shorter days that the 2 x 100ah lead acids may become marginal. I'm thinking of switching to Lithium before Autumn , this I believe ideally involves a B2B charger setup. Current setup is a Toptron EL537 distribution box and I believe the split charge relay resides within, which one of the two I've no idea , one I think states NONC 40A/30A, the other as no markings visible. The yellow wire to the side of the unmarked relay is I believe D+.
If I pull the 50 Amp fuse near the cab battery, the leisure battery no longer receives a charge on engine start up , the step still retracts on engine start up and the fridge works on 12V . So I'm assuming both of these are powered from the leisure battery. Do I need to check any other functions?
If the labelled relay is the split charge relay , and a B2B wired in series prior to this presumably it won't leave me with a lot of scope for charging power i.e 30Amp max according to that relay. I haven't properly checked the cable run yet, certainly it starts off at what looks like 16mm2 but looks possibly 10mm2 at the Toptron Battery 2 terminal
I was thinking leave the fuse out and run a seperate fused at both ends 16mm2 cable from the Cab Battery to Leisure Battery via a B2B- it will likely be a Victron 12|12 - 30A with bluetooth remote setup. Or do I use the original relay cable setup and hope it copes?
The Victron B2B , although it's got the engine start stop feature voltage detection I could feed the D+ signal instead.
Should I decide in future to have more charge power available I can add the same setup in parallel.
