Deepest condolences, they are not very good for leisure use.I decided to buy AGM leisure batts
Only when the engine is running always best wired so it is triggered by the alternator D+.So if i fit B2B, will it also charge batts when on hookup, or just when engine is running ?
Only applies to CBE distribution units, if you have a Burstner as in your profile you will have an Elektroblock.And reading other threads, they suggest cutting the r37 resistor, but I don't even know what this means !!
Cutting the R37 resistor in one particular brand of 12V distribution/fusebox will disable the split charge relay.And reading other threads, they suggest cutting the r37 resistor, but I don't even know what this means !!
They tend to have a very short life span, although they claim to be better for high current draw and you can discharge them lower in practice they don't hold up & they are expensive.What is wrong with AGM option, and what might be a better solution ?
There is a limit to how fast you can charge a battery. Obviously with a generator you want them to charge as rapidly as possible to reduce the run time. The rule of thumb is to not exceed about a fifth of the battery Ah rating. So if you have 2 x 100Ah batteries, you can charge up to 200 / 5 = 40A. The mains charger in your EBL will be 18A probably, so it would be better to get a higher capacity charger.Most recent brainwave is make system so it will charge rapidly from mains or generator.
I don't think that's a problem here. The maximum voltage the solar panel puts out is 23.4V. I imagine you are connecting the two panels in parallel (+ to +, - to -), so the max voltage of the two will still be 23.4V.but the votronic specs say 50v max whereas my panels seem rated at 60v -
- how significant is that 10v gap ?
"And now realised that Martin Bushnell / AandNcaravans is saying that uprating the original cables / Split relay will have nearly as much effect as B2B"
These solar panels can be used for many different applications. For example, in a solar farm, with dozens of panels wired in all kinds of series/parallel arrangements. For these particular panels you have to keep the maximum voltage to below 60V, so you can only wire two in series - three would be too many, and exceed 60V. Note that you can buy panels that can be used in arrangements up to 1000V.so whats difference between power voltage and system voltage ?
To charge starter battery on hookup you want a battery masterSo if i fit B2B, will it also charge batts when on hookup, or just when engine is running ?
I don't think the solar connector on the EBL 99 connects to the starter battery so you have to wire direct.So can I connect solar controller direct to starter battery, or will it have to go through EBL99 ?
Does the EBL 99 output 18A for both the starter and the leisure batts - do they get 18A each
Never heard of them before just had a quick look Australian company and they do have a range of B2B's.Lenny HB
hi Lenny
do you know anything about the Redarc system that is fitted to our Rapido i1090 Distinction
I’ve been led to believe that it’s a B2B charger similar to the Victron Orion I had fitted which was a 12/12/30, and that it has the facility to trickle charge the engine battery from the leisure batteries like the Battery Master does
If you can confirm whether or not this is the case i’d really appreciate it please
cheers
Al
There are a few different types of trickle-charger that will top up the starter battery from the leisure battery. Some only work when the leisure battery is being charged itself, by solar or EHU for example. Some work whenever the starter battery voltage is lower than the leisure battery voltage. A popular one is the Vanbitz Battery Master, which is available in the Motorhome Fun Shop which can be found here:who is battery master made by ?
Correct, I ran a cable from my votronic duo solar controller to a connection on the bottom of the ebl99 to charge the cab batteryI don't think the solar connector on the EBL 99 connects to the starter battery so you have to wire direct.
No, the starter battery charge is a 2 amp trickle charge and only when on EHU.
Maximum power voltage, refers to max voltage at max power for that panel. System voltage, refers to the hole system and that panel is part of, as in more panels. For example you can use that panel in series up to 3 panels, and stay within 60v system. House panels are rated at 1000 and 1500v, meaning very high and good insulation. Your rating of 60v system, tells you insulation can be breached if you go higher voltage. Most small panels have a system voltage of 600v, those are accredited panels. Yours it’s probably not, since it’s only 60v. Pretty weak insulation.thanks
OkVotronic provide a connection like that as an option with their dual battery solar controllers.
Well I’m not new to the game,and I’m not tearing my hair out………that’s only because I haven’t got any!Anybody new to MHs and their various charging systems would be tearing their hair our having read this thread and I doubt whether the OP is any the wiser.
May i ask, have you gitt a Redarc system on your Rapido.All I do know is that on my Rapido there is a battery charger that charges both the vehicle and leisure batteries whilst driving and when on ehu. And it can be left on hook up indefinately as it doesn’t cook the batteries. Seems to me that how they all should work…..anything else would be inadequate imo. I do not have solar.
My last Rapido did all of that but was a CBE system.May i ask, have you gitt a Redarc system on your Rapido
I’ve a 2022 i1090 and trying to establish if mine does the same
