ShiftZZ
Just like on many RV. Very useful fitting and the strength of the mighty triangle!I fitted clips on the side of our van that the feet of the legs clip into for such occasions.
If you put a few used tea bags in the water bottles the discoloured water helps stop the sun burning awnings etcWe used water to hold ours down once, & the sun went through & burnt the awning strap - it acted like a lens!
This is the solution we use. In fact, I've never used any other solution, even in perfect ground in perfect weather. It just works. Half the time we're on tarmac anyway!
I went for the aluminium version plus I mounted ours on a 4" square stainless steel plate to spread the load as I was concerned that the "C" class outer wall on ours is only a thin aluminium skin.I might mention that the plastic clips that came with the awning didn't last long. Googling for replacements, Fiamma (manufacturers of awning) offered proper metal upgrades. They've lasted the course.
Change the awning for a Dometic self supporting awning. Remote control operation, automatic wind sensor easy peasy
I love ours, and you can extend it all the way out, or, just a bit what ever suits
Trouble with those plates is that they don't allow you to put angles on the pegs so I'd never use them. If you don't have the awning too far out you could try what we used to do with the awning on our camper when on tarmac etc, basically the legs (blue) are extended and then angled so they go under the side of the van with a protective cover (orange) so they don't mark it, straps are then attached to the rolled out awning front and secured to the van (yellow) either bodywork/sill or wheels.
No leg supports needed at all? Is that a slide out photo copier?View attachment 630491
More sense with a picture
Nope 100% self supportingNo leg supports needed at all? Is that a slide out photo copier?
2 nice bits of kit there.Nope 100% self supporting
Nope its a slide out beer fridge it holds 2 x 18 slabs of Stella Atrois if Lyn doesn't get there first and fill it full of wine lol
