Awning sizes (1 Viewer)
haganap
12,754
26,415
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
I am after a Blow up awning like the kampa rally pro or similar or even a safari room.
However I am struggling to find one tall enough?
do you have one on your van and if so where from what size etc? I need it to be about 3m high..
tia
stewartwebr
1,105
3,408
Edinburgh
Morelo Empire Liner
36 years and 16 motorhomes
DuxDeluxe
14,657
72,613
Planet Zog
A woosh bang van
since 2008
Feb 24, 2013
13,054
101,387
Bolsover, Derbyshire
Hymer S800
not long enough
hello Paul, unless your wind out awning is one of those mounted right on the corner of the roof the actual height to the fixing rail could be quite a bit lower than your roof height
we ended up down the safari room option, but if you do get either style of awning buy yourselves a decent step up, 2.9 - 3.0m is one hell of a big stretch from the ground (y)
Jul 29, 2013
9,067
18,424
Salisbury
Hymer B678DL A class
since 2011
We have a Hymer Exsis and have a Kampa rally pro XL it's a great awning however we found it hard to use the wind out awning rail as it bends the awning and is hard to wind back up.
So I fitted an awning rail to the underside of the wind out casing and that works a treat. The only downside we have found I'd that it's a little too low and we have to raise the van on the EPs a little more to compensate as you need to get the blow out legs at the right distance from the van to enable the ends to seal against the van at the bottom,if you don't do that the outside legs bow slightly inwards when you pull the sides to the van sides to square the triangle.(if you understand what I mean)
Height to top of van 2.7m but to rail is approx 2.3m
