That did cross my mind but it's not that cold here really.Wonder if its temperature related?
Had that problem with several LED's only solution is to change them.
Yeah it's a line of LEDs mine failed after a couple of month so the dealer sent me a new one (I am going to repair the old one when I get the chance) easy to remove.Arrived on site today. MH had not been used for a while. Switched the awning light on this evening and noticed it was flickering. I think it's a line of LED's. Everything except the light is working well. Any suggestions as to the cause of the problem?
I replaced several of our bulbs with the same LEDs all at the same time. But only the bulb in the toilet flickered and popped. It wasn't until the 3rd blub that I realised it wasn't moisture that was causing the issue. It was the only light I regularly used while it was bright outside (no windows in our toilet). The high voltage the solar panel was frying the LEDs.Thanks for all the comments and advice good people. The light has now stopped flickering and is generally behaving. When we get back to base I will have the cover of and check it out. Ditcha that is exactly our unit. Do you have a part number to aid my search?
Now a different comment. Normally when a reply is posted to a thread I am following, started or posted on I get an email to tell me. This is now happening only some of the time. For example I started this thread and initially received emails but then they just stopped. Is there an explanation for this?
This is the label that was attached to the wrapping the new light came in .Thanks for all the comments and advice good people. The light has now stopped flickering and is generally behaving. When we get back to base I will have the cover of and check it out. Ditcha that is exactly our unit. Do you have a part number to aid my search?
