We don't have a wind out awning - we use a tarp instead which is mostly used as a rain shelter rather than a sun shade. But we're thinking of changing our MH soon and there's a fair chance the new one will come with a wind out awning - can they be used in the rain or are they really just for shade from the sun?Think of it as a sun shade, wind in when sun not shining !
........- can they be used in the rain or are they really just for shade from the sun?
They can be left in rain as long as it’s not windy and you peg down both the legs and use storm straps. Adjust the legs so that there is a sideways slope for the rain water to run off. Although you might think the slope away from the van is sufficient, the rain tends to belly. An extra centre support rail helps as do extra side rails.We don't have a wind out awning - we use a tarp instead which is mostly used as a rain shelter rather than a sun shade. But we're thinking of changing our MH soon and there's a fair chance the new one will come with a wind out awning - can they be used in the rain or are they really just for shade from the sun?
I use a tie down kit at either end AND a strap length wise right over the awning.. Stops flapping completely and has added securityThanks everyone will try a rafter pole and also be mindful to wind in at night
noGoing off subject slightly - when winding the awning out are you supposed to wind out so that the arms are absolutely straight?
No problem as long as you do not keep it in too long before winding out to dry. If you do you may get some mildew forming.Does it cause a problem if the awning is wound in when wet, assuming it is wound out again to dry once the wind stops?
You need a rafter pole either end and then these https://www.ebay.co.uk/itm/113718519029
We sell a lot of rafter poles and deflapper kits at shows, and use them our selves.
Many thanks.No problem as long as you do not keep it in too long before winding out to dry. If you do you may get some mildew forming.
We wind ours out until the awning material just tensions up. Winding out past this point and the material goes slack again.
This is what we do too. But until a Funsters pointed this out to me, I didn’t know you should do this and so had a baggy canopy which would flap in the slightest of breezes.I think the method used will depend upon the awning. The Fiamma on our previous van worked like that. But we have an Omnistor and the way it works is when it full out you flick over a lever on each leg which locks it into the front rail and stops it sliding. You then wind back it in a little against the lock to tension the fabric. Having said that our awning is 5m wide and I am not sure if the shorter ones have that lock system.
Been setting up this way for over 10 years. No flapping and no pooling!!!!!!!I would think that having a rafter at each end would encourage pooling???????
We always fit them a few feet from each end, works well for us!!
