Finally now have my Bailey Autograph 79-4
I am finding awning info a tad confusing the Kampa air 390 xl
Is for height 250-260,my height is 240 so am I ok with this 390
Or has anybody else got an awning on a bailey if so what do you recommend
If your height to the channel in the awning is 2400mm then 290 is too big. You probably need the L version. Our height is around 2350mm and use the Kampa Rally awning, this is usually used on caravans as it only has the 6mm bead. I pulled out the 6mm and shoved in a 4mm bead that I pulled out of an old awning.
