Hi, having a bit of a blank moment, my Avtex vision plus aerial, which bit should be pointing to the transmitter, the narrow pointy bit or the wide blunt bit?! I’m assuming the narrow bit!
ta
Yep... Narrow end.
Don't forget, it could be horizontal or vertical orientation.
If you can't get a decent signal try the other way or look for house aerials.
