Al n Val
- Oct 28, 2019
- 2,914
- 8,005
- Rapido i1090 Distinc
- since 2018
which arrow David as i’ve tried all 4 lolYup... Mine does that. You have to use the arrow next to the OK button to move on louder. once your past 21 you can then use the volume again. Its really annoying. I assume there will be a way to disable this in settings as its bloody pointless
no room for one tbh or i would, it’s an issue with a setting somewhere in the menu which i simply cannot find so no need for a sound bar i hopeGet a sound bar? We have an Avtex sound bar connected to our LG tv and it works a treat
That makes sense.Yep, mines the same.
You need to press the 'back' arrow ( as per screen prompt) to accept, then volume increase button as per normal.
‘Hotel mode’ so-called as it’s a feature most manufacturers hide in their menu system so that hotel guests cannot have the volume too loud and disturb other guests….That makes sense.
Mine did not do that but I think I had that "feature" off. It is possible on some sets to limit the volume and lock it, called "hotel Mode" bizarrely. Manual here around page 20 I think, if it's relevant to your model...
