Autotrail Cheyenne water tank syphoning why
John Liput
Autotrail cheyenne
Since 2019
Hi I'm new here, I'm filling my onboard water tank and it overflows and then syphons all the water from the tank, 2 overflow pipes run water out till tank is empty, the pipes are under the island bed as 2 u shape pipes Q is why does it syphon out??
:welco:
Have you checked the dump valve on the boiler is closed. If the tank is higher than the valve it will drain the tank if open.
Hi it's hard to get to the boiler to look for the valve but it only dumps if I over fill, but on the display panel it never fills more than 50 percent full. Not sure where the dump valve is
Thanks for the help but where is the reset?
Sounds like the overflow has been left too low in the tank.
It should only be just below the top but if it was just pushed in during installation it may well go right to the bottom.
I'm referring to the inside of the tank.
When you overfill the outflow will cause a syphon effect in the tube and draw all the water out.
You need to either pull the overflow pipe out and push it back in a couple of inches or undo the inspection bung and have a look inside.
Ignore the level gauge, they are seldom accurate.
Thanks will try that for starters
Clean the sensors in the tank if it's full and only showing 50%
Some friends on site here have had 3 Autotrails and told me the other day that all of them have had this ‘feature’. He had just put a watering can full of water in and it all came out again. Amazing!
I'd second PPJ's comments, it sounds like the overflow(s) are too low in the tank, if they were correctly installed then there's no way they could siphon off the contents.
You will buy British .. :) :whistle: :cry:
Loads on the Internet about the problem. Found one from 2008 so it's not a NEW Problem.
Join the Unhappy AutoTrail Owners Group on Facebook
  • Funny
Reactions: JaG
Not me, more than happy buying an Auto Trail, never had an issue... Also It maybe an age and lack of cleaning & flushing issue.
Reactions: TCG
I had the same problem. First time i filled up with water, more than half siphoned out. All I did was turn and rest the overflow pipes on top of the water tank.
