I have just got this camper van and find the seat a bit high for me at its lowest point. Is there any way I can make it lower. The year model is 2019 Thanks
If it has a swivel plate and you don't mind it not swivelling you may be able to remove the swivel plate and that should bring it down by 24MM or 1 inch .
There may be a leisure battery under the seat to consider.
Your local Motorhome Dealership or Fiat should be able to advise your options.
Removing the swivel base is gonna be the easiest 'fix', due to the wardrobe behind the driver's seat I doubt it would make any difference for 'leisure' use as you're likely not to turn it round anyway, just be aware that the seats are heavy so get someone to help you do it and also remove the plactic trim panels off the sides/front before you do it so you don't accidentally scratch them, they are just held on with bolts/screws.
