Billy Grumplin
- Sep 3, 2017
- 5
- 0
Hello Campers ,I'm thinking of buying 1999 ..5.9 metre arto bischoff with 2.8 fiat engine would like advice and jinfo to help me in this purchase......,
Damp damage to what ?I had one and loved it, the rear bed is a bit claustrophobic and the table got in the way so I removed it. Check for misting on double glazed sliding window panels in front as this is a an expensive fix. Make sure front roller blind fits snugly in runners. Failure to fit in runners is a sign of damp damage.
Enjoy
Not on a 1999, the HTC came out in 2001.Is it the 2.8 id TD?
D.
I can't imagine as the body is double skinned alloy on PU foam and the front cap that fits over is fibreglass.Damp damage to what ?
The steamy double glazing is an easy DIY fix for a couple of hundred £ or less.I had one and loved it, Check for misting on double glazed sliding window panels in front as this is a an expensive fix. Quote clipped.
Enjoy
I think the only place to check for damp is the garage floor as sometimes the door seals leak apparently the main body is double skinned alloy with no wood no nothing to check, I have heard of some people using a probe damp meter and they will show 100%Hello Campers ,I'm thinking of buying 1999 ..5.9 metre arto bischoff with 2.8 fiat engine would like advice and jinfo to help me in this purchase......,
This is not so I took mine to Polch, the N B factrory in Germany and the windows that were bonded in were cut out and replaced. They would not have done this if an easy fix were possible.The steamy double glazing is an easy DIY fix for a couple of hundred £ or less.
Martin
OK but they should be bedded on non setting mastic which makes it easy, somebody must have refitted them with Sikaflex at some time would be my guess.This is not so I took mine to Polch, the N B factrory in Germany and the windows that were bonded in were cut out and replaced. They would not have done this if an easy fix were possible.
Flaming autocorrect! The jtd engine was launched in 2001, prior to that it was designated idtd.Pardon?
Flaming new technology.Flaming autocorrect! The jtd engine was launched in 2001, prior to that it was designated idtd.
D.
