Apache entrance door rubber (1 Viewer)
Feday
35
44
Scarborough
coach built
Hello there.
I have a question regarding my 2007 Apache entrance door Rubber the black one with the air filled tube section attached.. i have a large split in the tube section of it and contacted Autotrail.. they said they no longer Make that rubber and to try magnum motorhomes..
I have found something 90% the same apart from small ridge on mine which magnum rubber shows not to have.. is it worth just buying it and trying to fit it...
Any advice would be great.
Sep 26, 2013
4,165
5,130
Market Rasen
Self Build
Since 2003
Have a trip to Magnums who are quite helpful, they will probably cut you a short piece to try.
Feday
Feday
35
44
Scarborough
coach built
Do they do a fitting service at all?
Sep 26, 2013
4,165
5,130
Market Rasen
Self Build
Since 2003
Don't think so, they have a van in the shop that they have been converting for the last three years as an example but it will never get finished. It should not be too difficult to pull the old off and put the new one on although you could always ask them.
You could then have a run to Cleethorpes which is far better than Scarborough, or you could even go down to Jim's 5 star super duper site.
