Thank you TonyidleAlmost any caravan accessory shop will have it. Or here:
CARAVAN/MOTORHOME AWNING RAIL INFILL/INSERT/MOULDING/TRIM/HERZIM STRIP 12mm | eBay
12mm nominally when fitted. Unit 15 Whitehall Industrial Park. bulk buy of 50m and 100m rolls also available in selected colours. short samples are 99p for as many colours as required.www.ebay.co.uk
Thank you Winger. I am checking to buy.Known as Herzim strip. Widely available on eBay for 99p a metre delivered.
wide range of colours.
There are different widths. Might be an idea to order a metre of each to establish which is the one you needThank you Winger. I am checking to buy.
Would not using a rule to measure the width of the original insert or channel be a cheaper option.
Just remember that when fitted it is meant to be proud of the opening with a curve for water run off.Thank you for all the information have received ...
I took a measure and is 15mm
So, should be good idea buy a bit bigger. Let say 17 mm? or even 20Just remember that when fitted it is meant to be proud of the opening with a curve for water run off.
Measure the old bit and buy the same sizeSo, should be good idea buy a bit bigger. Let say 17 mm? or even 20
