Anti-Glare Cover For Dashboard Media System Screen Ideas
Wombles
SW England
Van Conversion
A few years now
Spotted this & wondered if there is something like this that can be bought or if there are any other good solutions?
A glare protection for the navigation device​
Glare protection for the navigation device
What to do when the sun is blinding? Wilfried Hintzmann from Baunatal drives a Globecar Campscout FR, built in 2014, on a Fiat Ducato. The monitor of the built-in naviceiver is difficult to read in strong sunlight. A glare protection for the display was needed. Wilfried Hintzmann first made a template out of cardboard that fitted into the grooves on the center console between the radio slot and the adjacent air outlets. This cardboard pattern was then transferred to a 3mm sheet of rigid foam the color of the dashboard. Warmed up with a hot air dryer, it was easily bent into shape over a rounded board. The contours can be cut out with a cutter knife. The glare protection is fixed with adhesive rubber in the grooves on both sides of the naviceiver.
That looks really good and useful. I can't see anything on my double din head unit due to reflections, especially from the panoramic roof light.
Off to order some rigid foam now
Thanks👍
and it gives a flat surface to mount your Tyrepal monitor and dashcam onto!(y)
Thanks👍
Please let us know how easy it is to do & what materials you source. Wondered if it could be 3D printed but probably too big for that, plus would be heavy & expensive.
Thanks👍
Having a search around to interweb, it looks like it's Foamex that we need. (y)
<Broken link removed>
This is what I've ordered from Amazon.
3mm Black Matt Foamex Foam PVC Sheet 13 Sizes to Choose (420mm x 297mm / A3) Amazon product ASIN B00QQGGRKY
I've got some black U shaped trim lying around as an alternative to the chrome trim shown in the OP photo.
