Amazon Firestick used with a 19" Cello Traveller TV (1 Viewer)
Jul 5, 2013
11,723
13,702
I have a 19" Cello Traveller TV and want to buy and use an Amazon Firestick to watch occasional UK TV while we are in foreign parts. But I have a couple of questions from people that may have this or similar set up already.
Firstly the HDMI port is set in a recess in the back and there is only 70mm or so between the port and the back of the recess. The Firestick is about 89mm long so I do not think it can be pushed directly in. Is there anyway I can overcome this, maybe by a short HDMI lead or a 90 degree HDMI adaptor?
Secondly does the USB socket in the Cello give enough power to keep the Firestick running or will I have to run a lead from the nearest spare USB port in the motorhome?
Many thanks for any help you can give.
Chipster
1,008
1,120
East Midlands
Getting there!
I use firestick on cello traveller. Have indeed added an adaptor for hdmi and run it off the usb (the one on the Android side)
AndyPK
5,012
13,896
Cirencester
None……..!
Motorhoming since 2015......
Did your Firestick not come with a short HDMI extension lead.....?
I power my Firestick from the USB socket on my Manta tv, so your Cello should work too, I would have thought.....
Apr 6, 2019
3,737
7,448
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
Look on Amazon or fleabay - HDMI extension lead OR the HDMI right angle connector - both entend.
Or think ahead and get a switch (allows 2 HDMI into one and includes a short extension).
peterc10
Jul 5, 2013
11,723
13,702
I haven't bought it yet, but looking at it on the Amazon site it says it includes a HDMI extender. Is that what you call the HDMI extension lead? Is it a case of plugging the male end of the extender into the TV port and Firestick into the other end?
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
I have exactly the combination you have and the extension plugs in to the HDMI slot and you then plug the firestick into the end of the extension. The extension comes with the firestick. I use a separate USB supply but I have never tried it from the tele.
It works a treat using my mobile as an internet hoptspot.
May 31, 2015
11,679
44,512
Ducato PVC
Getting Better
‘yes peter, the fire stick 4K comes with a short hdmi cable about 3-4ins long so will tuck behind your tv ok, we have a usb extension taped behind our tv that it plugs into and works fine, if your tv one is not up to it that would be an option...
TerryL
6,180
8,180
North East
Low Profile
We have a spare cig-lighter type socket close to the TV so will be using one of those USB adapters in it - but if you decide to go that way make sure the adapter puts out a decent amount of power as many of them are only 1w which is probably not enough for the Firestick.
And I'll confirm also that the Firestick comes with a short extension cable.
peterc10
Jul 5, 2013
11,723
13,702
Thanks Garry. Was not going to get the 4k one because I really think it will not look any better on a 19" TV. Or is there any other reason to get the 4k one?
May 31, 2015
11,679
44,512
Ducato PVC
Getting Better
I have no idea Peter, but sue mainly watches it now on the house tv and we have taken it away in the van for a month when we went to southern France, it worked a treat connected to Sues hotspot on her phone with 100gig data....
AndyPK
5,012
13,896
Cirencester
None……..!
Save your money - don’t buy the 4K one as your tv would not support that resolution anyway - the ‘standard’ Firestick with Alexa will be fine, and is on sale for £19.99 on Amazon at the moment!
AndyPK
5,012
13,896
Cirencester
None……..!
Actually £19.95 at Argos........!
peterc10
Jul 5, 2013
11,723
13,702
Following the brilliant help on this thread I have just bought the £19.99 one from Amazon. Preferred that to anywhere else because they will link it to my Amazon account before they send it out which will save me some time when setting up.
Thanks everybody for all of your help. Once again it shows what a great community we have in MHF. (y) (y)
Satandpcguy
Jun 18, 2008
693
421
Gandia, Valencia, Spain
Don't own one yet
...use an Amazon Firestick to watch occasional UK TV while we are in foreign parts.
Remember that if you want to use the likes of iPlayer ITVHub All4, a vpn / smart dns service will be needed to hide your foreign IP address...(unless you are using a mobile data hotspot that gives you a uk ip address)
6
63720
When you set up the Firestick in one of the menus activate Data Monitoring, this allows you to select 3 different levels of quality thereby saving data. You can also pair the Firestick remote to the TV so you only need one handset controller.
peterc10
Jul 5, 2013
11,723
13,702
Thank you. We will be using my mifi or phone, both of which have UK SIMs in them. I think that will mean that we will not need a VPN
jumar
3,774
11,585
Spain
Hymer Tramp
Since 1994
Mine works, same set up as you intend using....the hdmi short extender supplied with the stick is all you need...the power supply via usb is sufficient from the Cello.....all in all the right way to go.
pwilmo
344
544
Kings Lynn, Norfolk
Auto Roller 747
Hello there
Firestick Techies ... Can anyone tell me how much data Gbyte an hour on the Firestick would use ... watching Emmerdale / Corrie maybe catchup whatever.
I have a UK data Sim for Mifi and was wondering how long 25GB will last her indoors for the soaps, any sensible ideas please?
17,630
43,258
Hello there
not using HD then the firestick uses about 1/2 Gb per hour, so 25Gb would give around 50 hours viewing
pwilmo
344
544
Kings Lynn, Norfolk
Auto Roller 747
Many thanks, brilliant, MHF does it again.
Cor Blimey, the missus is costing 50p to watch Emmerdale ... but what cost peace and quiet!!
