Hymerbell
- Apr 2, 2014
- 1,112
- 2,583
- Hymer 674
- Since 2002 plus 20 years in a tent
Does anyone know if it is possible to clean this aluminium trim
I’m getting confused now....what does everyone mean “removing the anodised aluminium”.Solvol autosol will do it but beware its a bit like Brasso and windolene, get it in the wrong place and it will discolour anything it comes into contact with especially when you start removing the anodised aluminum. Seeing as we all have time on our hands would it not be easier to take the trim off and get it coated before refitting it? Never done it but have powder coated items in the past and anoised ally items
What they mean is that the aluminium trim is Anodised and using Autosol will remove the anodized layer leaving bare aluminium. Which will then need polishing and protecting.........constantly ?
As already said, a non-abrasive cleaner is your best bet as a first attempt at cleaning it.
Ooh err....what about this then....does this work....and not take off the anodised layerThe trim when fitted would have been polished and a lacquer or clear coat applied over it, over time the coating has become damaged with either cleaning or stone chips, when exposed to the air, rain and road crud the aluminum trim forms a catalytic reaction and discolours which is what you have. think of it as the aluminum equivalent of rust and in time, a very very long time it will eventually dissolve away. When you polish it you are taking of the layer that has reacted and so the cycle will repeat unless protected, If you are going to treat it then either be prepared for polishing every 12 months or so or take the trim off and get it professionally coated. When you apply the polish the anodisation comes of as a very grey paste which will stick like stuff to a blanket it will discolour the majority of things it comes into contact with. Does that help?
