These Classified Forums are now archived, so you cannot add to or edit them. Our New Classified System can be Found Here
Sidney, what is the slab for??Long shot but does anyone know of a competent bricklayer in the Stamford/Peterborough area?
It's a simple job, just a base line of blocks so we can cast the concrete slab.
Unless there is going to be more than a single line OR footings below ground for your single line then the concrete will in all likely hood burst open your row of blocks,Long shot but does anyone know of a competent bricklayer in the Stamford/Peterborough area?
I had some forethought in one of my sons becoming a builder, he is building my extensionSorry to explain...
Its an extension, it's a standard construction, one section 2-storey, one single storey.
Trench fill foundation are poured.
Before the inside is backfilled with hardcore (and concrete slab) I'll need the first run of double skin 7 Newton blocks in place and ideally the splash course engineering bricks. I can then put in stone and compact
I'm after a bricklayer as the one I was going to use is unavailable.
Full spec
25.7 linear metres of blockwork on new, level, trench fill foundations. single course, double skin, 100mm blockwork (120 blocks.)
Three corners, one angle.
Would also like splash coarse (blue brick) and inner skin to be laid ready for stoning up and concrete slab.
I don't have a bricklayer arranged for the main build. The plan was to get the messy work done now and crack on with DPC upwards in the New Year once the snow/frost has gone.Sidney,, is it just for the footings and the one skin you need a bricklayer for, or all the brickwork to plate afterwards?
