It just provides additional support and reduces sway when being overtaken. It won't level the motorhome front to back unless you go for full air all round. I believe the Goldschmitt system achieves this but is quite expensive.Does this just add extra support to the existing Alko torque shafts or are they removed. I ask as my van sits nose down so to level I need the rear to go down, cannot see how that can happen with the torque shafts still in place.
Sounds like you need uprated springs on the front, just had mine done.I ask as my van sits nose down
Was it just springs at the front or was the whole strut assembly replaced? My AlKo chassisd van also has it's @r$e in the air. Raising the front would seem the simpler solutionSounds like you need uprated springs on the front, just had mine done.
Common feature on A class vans
The one we had was dearer but you might like to have a look at the quality of the stuff being fitted (not just the air-bags).Thanks just had a look 1750€
Does not always work. The Hymer B678 I bought from new has an Alko maxi chassis and uprated springs on the front but still sits nose down, despite the load on the front axle being considerably lower than the maximum. I think it is (or was) common on motorhomes with the Alko maxi chassis.Sounds like you need uprated springs on the front, just had mine done.
With the semi Air the I'm fairly certain the torsion bars are left unchanged, with full air the torsion bars are changed for lighter ones. The torsion bar are required to locate the swinging arm.Does this just add extra support to the existing Alko torque shafts or are they removed. I ask as my van sits nose down so to level I need the rear to go down, cannot see how that can happen with the torque shafts still in place.
Dave Newall and £800Where did you have the springs work carried out and how much
Correct, this is a benefit of the semi-air being a 'secondary' suspension system in that if one fails you still have the other to ensure you can drive it.With the semi Air the I'm fairly certain the torsion bars are left unchanged, with full air the torsion bars are changed for lighter ones. The torsion bar are required to locate the swinging arm.
When I was researching semi air for alko Travel World ( goldschmitt?) were replacing the torsion bars with "softer" bars so any problem with an air bag meant a recovery lorry. All others I visited or rang kept existing the existing torsion bars.Correct, this is a benefit of the semi-air being a 'secondary' suspension system in that if one fails you still have the other to ensure you can drive it.
Now you mention it, that rings a bell and one reason why we didn't go for their system as we prefer the 'belts and braces' of having both usable independently if the worse happens.When I was researching semi air for alko Travel World ( goldschmitt?) were replacing the torsion bars with "softer" bars so any problem with an air bag meant a recovery lorry. All others I visited or rang kept existing the existing torsion bars.
Edit, this was back in 2017/18. May have changed since
It depends where you’re starting from, our rear axle was at its limit and therefore needed assistance from the air bags. If the springs are already up to the job and fully supporting the rear end then adding air isn’t going to change the ride, except for maybe controlling side sway a bit.When I was researching semi air for alko Travel World ( goldschmitt?) were replacing the torsion bars with "softer" bars so any problem with an air bag meant a recovery lorry. All others I visited or rang kept existing the existing torsion bars.
