Alko axle greasing is not at all difficult! (2 Viewers)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
There are many misguided posts all over the web about this so here it is simplified.
Tales of having to jack up so both rear wheels are off the ground at the same time is both unnecessary and unsafe.
All you need is reasonably level ground with the engine in gear and the wheels chocked.
The handbrake must be OFF!
One side at a time just lift the chassis as though you were going to change the wheel.
Then with a properly bled grease gun pump in several strokes of lithium high melting point grease.
Repeat for the other side and replace the nipple covers.
How easy is that
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Depends who built the van on some models the grease nipple is not accessible without dropping the axle. Daft I agree
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Sorry I only play with proper vans like Rapidos :D
Reactions: OG1
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Actually I did appraise the possibility of this happening and it's a deffo no go for the poor sods (y)
Rayb182
Nov 13, 2009
1,523
2,223
Great Bentley
Sundance 590 PR
Since 1999
Looks like mine underneath, done mine a couple weeks back, one grease nipple wasn't letting any grease through, unscrewed it put a new nipple in, while nipple was out found there was no grease in axle, good job I did it.
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
seeing that grease gun took me back i used to grease my brothers artic tand trailer every month for pocket money usually had more on me than on the motor
Jan 22, 2013
1,252
60,077
London SE
A class Adria vision I707
since 1971
Some Alko chassis don't have grease nipples, and are sealed for life,
Mine is that type,
but I would have preferred some then at least you know it's lubricated
icantremember
8,332
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I agree with you Andy that it is a simple job and I do my own regularly .... however I would not work under any vehicle supported on a scissor or hydraulic jack without using axle stands and I'm sure yours are just out of the picture. To enable the axle to hang free the stands need to be under the chassis and not the axle.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
No as the wheel is not removed and there is more than enough clearance under my van for this job.
icantremember
8,332
17,545
Hymer T-SL668
since 2005
I'm sorry to dissagree on this point, maybe mine is lower or I am of larger proportions but I would still not risk it without the stands and would not recommend anyone else does ..... it doesn't add much time to the job and my fire service training has taught me that safety should be a prime concern at all times.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes you must do your own risk assessment with any job.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
My pleasure thank you.
Better picture with a real camera of my ground clearance
I don't actually need to get under the van either I can quite easily reach the nipple without
Both sides took about a dozen pumps before the grease started backing up.
barrywi
120
28
Cumbria
I am a Newbie to motorhomes but have caravaned for years
Warning . My scissor jack supplied with the vehicle collapsed when I was swopping wheels to paint them. It may have been slightly off vertical , but it made me think about future use of such a device. I now have a four ton bottle jack in the vehicle ( not expensive or particularly heavy) and have bought some new axle stands. I also put my trolley jack under the vehicle when at home for good measure. Better safe than squashed.
My van is 4000 kg rated
Sep 28, 2015
2,015
2,607
Hymer B544
2001 Caravans 2011 Motorhomes
I know this an old thread but I've just done my 2014 B544 this afternoon, very simple job that Lowdhams wanted £45 to do in addition to the service cost. The difficult thing was getting the alloy wheels off as no grease had been used and they were stuck solid.
I used my trolley jack, axle stands and wheels off as it made it easier to reach.
Check out Granville grease, it meets the Lithium based, extreme pressure requirements.
icantremember
8,332
17,545
Hymer T-SL668
since 2005
Why did you have to remove the wheels? ... I do mine easily with them insitu.
Sep 28, 2015
2,015
2,607
Hymer B544
The side skirting bodywork comes down quite a bit for access and to get my axle stands in securely I would have had to jack it quite a bit higher. Plus, taking them off is an opportunity to have a look at the tyres and brakes.
I noticed on Lowdhams service plan it says 'without removing road wheel', one of the things that put me off.
Because it's a very simple thing to take the wheels off (when they are not seized) it seems sensible to give myself more space/light.
Aug 18, 2014
23,765
133,473
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
How many pumps pers side would be considered normal each year ?
I've just done my mate's & it took 46 each side + one new nipple as it wouldn't reseal.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
7 to 12 on mine as soon as it starts backing up out of the nipple. Did you check the gun was primed fully first and not pumping air
Aug 27, 2009
19,788
23,068
Hertfordshire
40 years
How easy is that
I last did this some years ago when I had an Alko set up. Glad to see the method hasn't changed since then.(y)
