lunarman
Just spotted this Broken Link Removed on special in ALDI today has 12v adaptor and satellite tuner. Might be of interest to some on here.
I had a look. I didn't see a satellite receiver, but it has everything else.
Have a look at the second picture of the connectors you will see an LNB in connection. Also features state dvb-s2 tuner.I had a look. I didn't see a satellite receiver, but it has everything else.
I bought one when it came out last month, was really disappointed with the delivery service - they took a week to dispatch
But then was even more disappointed when I flipped it over and found the vesa mount on the back was 200mm x 100mm, when most vesa wall brackets I've found are 100x100, or 75x75
It went straight back
Not really. It has HDMI anyway. No technology is involved in SCART as it simply gathers existing connections into one oversize plug attached to cable that doesn't bend. It still has occasional outings with legacy stuff..Must be an old model if it has a Scart socket...
Very good but just in case someone thinks that they can use that to control a roof top sat dish they can't. If will only take the LNB signal from a fixed dish or already tuned one.Have a look at the second picture of the connectors you will see an LNB in connection. Also features state dvb-s2 tuner.
Not sure, but from what I gather arc is standard these days, you just need a new-ish HDMI cable.Has it hdmi arc?
It does power my sat finder. I have a manual dish.Very good but just in case someone thinks that they can use that to control a roof top sat dish they can't. If will only take the LNB signal from a fixed dish or already tuned one
hopefully a link to the manual here
