Aldi heating not working on electric
Durham, UK
Swift Bolero 714SB
Since 2018
Can you help the Aldi heating will work on gas but not electric, thanks for any suggestions
Jeff 👍
Check the MCB in the main board Jeff, it may have tripped. Is anything else that works on mains working?
If it isn’t that, there is sometimes a fuse in the connection unit to switch it on near the unit, should be a simple 240v switch.
Finally, make 100% sure electric is selected as the primary energy source, they are complicated buggers the controls.
Could try Lidl :roflmto:
Seriously though the first heat up cycle can take a long time if you don't select gas too to give a boost. Even at the 2kw setting, the electric heating for Alde is not that great
What model / controller have you got, on ours we have a 2 pin plug symbol when on hook up, that would be my first check
Then a look at fridge to confirm that is working on mains 👍
We have had two vans with Alde heating and both after lack of use have needed to be run on gas boosted up and then all was well again.
