Alde wet heating advise (1 Viewer)
Lanerboy
1,363
2,206
midlands
Carthago 4.9 superior
Hi All
My 2016 Rapido has the Aldi wet heating system fitted its the 3020 system and after browsing through the brochure it appears you can control it from your phone.
My question is does this come as standard or is it an extra as it needs another control panel where the sim card needs to be inserted and I don't know where this may be located if it's ever been fitted or do I need to get the sim card holder/controller fitted as an extra
Cheers LB
Aug 19, 2014
1,851
5,553
Cliftonville
A Class Burstner
Since 2014
Hi All
Cheers LB
If you have the Swift Command system, it can remotely control the Alde 3020 heating via your phone
canopus
6,127
10,237
rural Lincolnshire
Carado CV640 Pro
Since 2010
The OP says he has a 'Rapido' which does not have the same Control Panel/System that 'Swift' use. :eek:
Apr 9, 2014
1,307
6,595
Lincs
Looked at this at the NEC one year, I think the cost to get it added to existing 3020 system was around 300.00, for what it added not worth it for us.
cornish boy
892
2,365
Body in Hampshire, heart in Cornwall
Swift Kon Tiki 669.
not so newbie anymore - since 2016
We have control of the heating via the Sargent control system on our Kon Tiki.
To be honest it is more of a feature rather than a benefit, used about twice (just because I could) but mostly put the ALDE on automatic and let the thermostat do the work.
The best and most important benefit we have is the remote ability to prevent arguments through being able to turn off (or on) the lights from the iphone or ipad when we have both gone to bed and realise a light is left on at the other end of the motorhome! (y)
canopus
6,127
10,237
rural Lincolnshire
Carado CV640 Pro
Since 2010
I think the main idea with the Alde phone app is that you can phone up and have the water and heating to temperature when you arrive at the vehicle - not really intended to use it from the bed at the rear of the van. :LOL:
cornish boy
892
2,365
Swift Kon Tiki 669.
Yep, I fully understood what Lanerboy was referring to. The sargent system also allows control locally via bluetooth or remotely by phone. We use our motorhome all year round and have never had the need to ring the van and turn on the heating. The alde wet heating is not instant heat so it tends to be turned on already if it is, or likely to be, cold. As I said, I have used it about twice to turn up the temperature but only because I could, not because it was needed.
As I said, good feature but not a great benefit.
