Alarm problem
Cosmo15555
Hertfordshire
Elddis majestic 195
I collected my MH from storage and found there’s no alarm chirp when arming and disarming the alarm
I have now found that there’s no sound when alarm goes of
I can hear a clicking noise similar to a indicator relay in drivers side door Rear piller
The red light in centre door lock button flashes and the alarm system has a extra blue light which flashes 3 quick times
The light in dash clocks with picture of car with padlock is also illuminated
When I activate the panic button from remote the lights flash but no noise any help would be gratefully received
Cosmo
Not sure it’s a Peugeot and I’m guessing it’s factory fitted
if it's factory fitted, it is not worth having anyway, so easy to defeat
My Sigma alarm threw a wobbly today at Dave Newalls place
Had to start it by using the little key pad.
When I got home I had to re-programme both key fobs, never done that before but all looks ok now
It has the autowatch 362000 intelligent ultrasonic sensor fitted if that helps
It tends to be fitted behind the off side headlight.
As the fob is autowatch would that be factory fitted and genuine Peugeot siren
Can you let me know where the siren is located please
it all depends where the installer has fitted it, ours was under the bonnet fairly central on the bulkhead.
Autowatch is a post fitted system (not standard equipment)
I can’t see the siren in view but the wire for the bonnet tamper goes to the offside somewhere
That is only a part number for the ultrasonic sensor itself, not the alarm system.
Peugeot do not factory fit Autowatch alarms. It is likely to be an Autowatch 695RLC which tend to be fitted.
Thanks for all your replies
Any suggestions on where best to get a new siren from
Siren located but who ever fitted it put it facing upwards so held water like a bucket
Would it be recommend when the new 1 arrives should I take van apart to connect siren to main control unit which I think is located in drivers side door rear piller or can the wires be spliced
The model alarm is 695rlc with 375800 siren
Thanks again for the help received last night
