Hi, I know many of you have the Vanbitz Strikeback / Growler alarm system so I thought I would ask on here first about a small issue I am having before bothering the chaps at VanBitz.
When I set the alarm, the lights flash twice but then I get four beeps as well as it arms. The handbook says this means there is a fault and to check the doors and lockers are shut. Well there are only the two cab doors, one locker door and the habitation door so it is fairly easy to check they are all secure. The accessory loop is switched off and not plugged in and the internal sensor and sounder are switched off. I would be grateful for any suggestions as to the likely cause.
Thank you.
Thank you.
