aircon recomendations? (1 Viewer)
tommytli
May 26, 2009
434
26
lancashire
coach built
since july 07
after my recent trip to italy im wanting aircon, any recommendations? do they run on 12v aswell as 240? are they quiet?
W18BLA
Oct 24, 2009
348
33
West Midlands
RollerTeam
I have the Dometic 2600 with 12v addon it is good abit noisey on cooling but when its at its optimum temp it sits there nice and steady, But the one we have is climate control, And then there is the cost £3k fitted alot of dollar..:cry:
Craig
dennismartin
135
19
hull
c class
im a newbie
hi
i have just got a dometic 2100 from olearys £450 new but old model
dennismartin
135
19
hull
c class
im a newbie
dont go for the smaller ones that he has
dennismartin
135
19
hull
c class
im a newbie
you will nead a 3 kw inverter to run this you can pick them up for £175
dennismartin
135
19
hull
c class
im a newbie
i have only just set mine up on inverter today not tested it but it will use a lot of amps i think about 85 im sure some one will give you the answer it is a 900 watt air con 1200 watt heater
i will only use mine on inverter while travelling as and when needed 1 have 4 115amp batteries 300watt solar panels not that they will do much
T
tommytli
May 26, 2009
434
26
lancashire
coach built
since july 07
so am i right in thinking unless you have a good electric supply you cant have the aircon running at night while sleeping?
and if thats the case while i was in italy and needed it the most and the 3 and 6 amp supply would have not been enough to run it?
scotjimland
2,241
9,748
A Woosh bang
Yes and no..
The smallest Dometic has a cooling capacity of 1kw , uses 2.1A , this will run on a 3A supply but MAY trip the ehu breaker on start up .. so if you really want one it's worth the risk.. provided you can reset the breaker without having to wake the site commandant ..
Cooling capacity (kW) 1.0
Full Load, cooling (A) 2.1
Capacity (BTU/h) 3400
Power (V/Hz) 230 / 50
Refrigerant R407c
Dimensions (L x W x H) (mm) 980 x 650 x 235
Dimensions (roof opening) (mm) 400 x 400
Net weight (kg) 29
Circuit (A /sec) 11/0.15
Consumption, cooling mode (W) 500
Consumption, heating mode (W) 800
Fan speed (kW) 2.0
Fuse (A) 3
Roof thickness (mm) 25-45
http://dometic.com/enie/International/Site/Caravan/AirConditioners-Ventilators/product/?productdataid=66587
tonywolst
81
28
Shropshire
newbie
I have one but cant remeber the exact model number Think Its a dometic B1500, Cost me £300 and i fitted it myself(dead easy), Only triped out the ehu once when I put the kettle on at the same time by mistake, Im only 6m long and it worked perfectly, the noise never botherd me as I couldent sleep with the heat, I rekon its the best thing i ever did:thumb:
motor roamin
May 23, 2010
1,541
792
Leicester
2 mins
Yes and no..
Refrigerant R407c
Net weight (kg) 29
Fan speed (kW) 2.0
Fuse (A) 3
http://dometic.com/enie/Internation...ners-Ventilators/product/?productdataid=66587
Jim I might be talking out of the wrong hole :ROFLMAO: I am a mechanic not a sparky, but couldnt start up be softened so as not to have such a surge on start up.
All the best Rick
Oct 29, 2008
5,057
5,910
West Yorkshire
PVC
since 2008
We have an aircon unit fitted in our double floor, its a Truma model, it is very quiet unlike the roof units I have heard. We fun it on fan only on a 500w inverter while traveling.
eddie
8,141
41,173
Taunton Somerset
RV
since 1989
All the best Rick
All Dometic units are have "soft start" relays. If fitted by a DMC (Dometic Motorhome Centre) you will get a three year parts and labour warranty and many (we do) will offer free fitting over the winter period
Hope this helps
Eddie
dennismartin
135
19
hull
c class
im a newbie
3kw inverter off ebay runs all electrics great
eddie
8,141
41,173
Taunton Somerset
RV
since 1989
didn't know that Eddie... thanks for that ..
do you have any technical details.. ?
jim
Hi Jim
No not really, the thing is that Dometics marine division is huge and has a range of devices to stop problems with generator and shorepower conection. So other than telling us that they're soft start we don't get told that much
We use a soft start relay kit designed for halogen lights (patio heater type) to elliminate the problem of tripping the site when connecting RV's up usually caused by the transformers.
So we assumed that Dometic crossed a bit of technology over from their Marine devision
Eddie
scotjimland
2,241
9,748
A Woosh bang
be aware , you will need a big battery bank to use a 3kw inverter
3kw from a battery at 12v will pull 250amps .... how long will 100ah battery last ?
about 12 mins..
also, leisure batteries are not designed for heavy loads ... to use this size inverter at full load you would need a bank of traction batteries.. and a trailer to carry them
by all means use an inverter but do the maths before buying ..
dennismartin
135
19
hull
c class
im a newbie
my 3 x 115 amp batterys lasted 2.5 hours at 900w
scotjimland
2,241
9,748
A Woosh bang
sounds about right .. 0.9kw at 12v = 75A x 3hr = 225ah
115ah battery x 3 = 345ah .. recommended max discharge is 50% of that = 172ah
so your battery bank was discharged to 76% .. not recommended, you will shorten their life if you keep doing that
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
I've been thinking of buying a domestic freestanding unit to use and cart with me only abroad. Has anybody tried this? any thoughts?
