Aircon question (1 Viewer)
Oct 23, 2009
784
608
Anglesey North Wales
Adria Twin 640SLB
Since 2010
After this summers really hot holiday in Europe with some sleepless nights despite using the endless breeze fan I am thinking seriously about fitting aircon.
The question I have is :- Can an aircon unit if fittted to my van next year be moved to another van should I upgrade in a few years time or am I just expected to pass it on to the new owner ?
Thanks for any advice .
ambulancekidd
Sep 23, 2014
10,365
28,388
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
The unit can be removed & installed onto another motorhome with relative ease. Some of the newer Dometic units can be used on the go as well as on mains. The hole in the roof for a skylight is the normal place to mount the unit, then simply replacing the aircon unit with another (or the original skylight). Getting the motorhome nice & cool even before you arrive on site has to be worth it.
11,183
17,821
HYMER B644
Yes it can.
The roof mounted more easily.
But I would fit (if you can) a Truma Ducted type. Only problem may be patching up the holes in the floor.
I am an RAC Engineer (refrigeration and air conditioning (not the AA competitor)). I have fitted roof mounted and Ducted. Ducted are much quieter when fitted correctly.
Jul 18, 2009
11,183
17,821
HYMER B644
I meant to add....
For use on the move. A powerful alternator/Solar, batteries and a good charger are required. Along with an Inverter that can handle not only the power draw, but also the initial high current draw to start the compressor.
wp1234
Oct 23, 2009
784
608
Adria Twin 640SLB
Since 2010
Yes it can.
Not looked at this option but looks interesting assuming it can be retrofitted to my Rapido , does it use the same ducting as the Trauma air blown heating or is or separate ducting and if so space would be an issue
Hellski
989
2,972
Cheltenham
N+B Arto 76 LE
Personally, I can't see why it can't be tee'd into existing ducting.
Badknee
7,407
412,580
notloB
Vantage Neo
Living the dream.
Yes it can.
I'll second that, super quiet. (y)
Jul 18, 2009
11,183
17,821
HYMER B644
No, you have to use cold air hose and in some parts I insulate it.
Retro fitting can have its drawbacks and the logistics (if those are the correct terms) can be awkward. But, where there is a will there is a way. I had a problem getting to part of the habitation area around the table. Too tight to get past rear seat belts and other obstacles so went through the bathroom. I will take and post a photo of what I did.
TM
wp1234
Oct 23, 2009
784
608
Adria Twin 640SLB
Since 2010
I'm sure loads of folk have been down this road before me having suffered extreme holiday heat abroad .
Of course it will never make financial sense to fit aircon for say 14 days use per year but that's a personal choice. I've made the choice and I'm happy to spend the £2k required for a decent sleep question now is what's the best unit to buy for the buck. The Truma ducted sounds good but retro fitting in my unit looks difficult so it's a roof unit for me so I'm now looking for best value choice and where in the North West to get it fitted.
Jun 10, 2010
8,507
20,218
Shrewsbury (sometimes)
N&B Clou Liner MAN
The problem with routing through existing ducting is that truma heating ducts tend to be installed at low level due to the fact that hot air rises. Cold air however falls so you would need to install vents at high level or you would get very cold feet and not much else. Nice idea though.
Jul 18, 2009
11,183
17,821
HYMER B644
Truma call it the "
"Saphir EasySet for eco solution"
R
Robert Clark
We had the Dometic Freshjet in a previous van
http://www.jacksonsleisure.com/cara...shjet-2200-motorhome-caravan-air-conditioner/
Picked this website purely as an illustration
Easy to DIY install, as it works on a standard 400mm roof vent opening.
It requires a 230V and a 12V power supply, which easily connect to the unit.
All of the 'gubbins' sits on the roof, with an internal outlet inside the van.
Although the current draw is low, it won't really work off batteries and should be connected to EHU.
Because we mainly wild camp and are seldom on EHU we removed it and replaced it with the original factory fitted fanned roof vent, which we found gave adequate cooling, without draining the batteries.
Edit;
You may get complaints from adjacent campers if you leave your air con running all night as its a bit noisy when it starts/stops.
TerryL
6,180
8,180
North East
Low Profile
Aircon came with ours when we bought it; at first we thought how lucky we were, but over the 8 years we've had our van, it's been used "in anger" just twice! This is mainly because we tend not to use campsites if other places are available, and on the "cheap" sites we use (including ACSI) the amperage is hardly ever enough, think tripped bollards.
It's now starting to get a little "tired" (it gets tested occasionally) and apparently is not serviceable (well, at a reasonable price). Have thus seriously been thinking of taking it off (gaining a nice chunk of payload) and fitting one of those reversible fans that run off the 12v system.
Sep 3, 2009
1,532
6,282
NW Surrey
LHD Hymer exsis-i
I remember 20/25 years ago at the old Albatross site in Spain paying extra to have an up-rated breaker fitted to run our aircon in the RV each time. Absolute bliss!
Malcolm
Jul 18, 2009
11,183
17,821
HYMER B644
I ducted our Truma to
Living / Dining area*
Rear Bedroom
Over door towards cab area.
*The one over the pullman diner had very restricted space for ducting. So as I said, I made a duct with large cable trunking and took it through the bathroom.
See Images.
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Does anyone know if Alde heating system is air con as well?
Happy1
516
220
Wales
Rapido A class
12 years
underbench is definately quite, had a dometic in previous van - all good, went for truma this time around - all good as i liked the idea of adding air con to the cp timer controller already fitted, supossed to work on bluetooth from mobile but not at the moment - thats another story - and via sms if further away.
Jan 19, 2014
9,385
24,754
Derbyshire
Elddis Accordo 105
since 2014
No, only works the other way round.
Some Air con units have/can have heater coils fitted to blow warm air.
Proper air con needs a compressor and condensor like in the back of a domestic fridge.
Don't know about air con in vans but building A/C achieves heating by reversing the flow of refrigerant with a 4 way valve. Thus the evaporator becomes the condenser.
Mind you some Mitsubishi units years ago had a heating element to help out.
