Airbag warning light - help please (1 Viewer)
Candapack
711
2,639
Fife, Scotland
So, heading off to Spain, leave home Wednesday. Just moving van this morning, airbag warning light not going out and message "Check Airbag" flashing. Manual no help, nearest Fiat Pro outfit stacked up with work.
If it means that airbags might not deploy, then I'm not too worried. After all, most of us have spent years driving without airbags.
But if it means the airbags might deploy unexpectedly, well that's a different matter.
Any ideas?
Feb 16, 2013
19,687
51,832
uttoxeter
ambulance conversion
50 years
Any ideas?
Try undoing and doing up again the connecter under the seats, sometimes they get disturbed if moving seats or swivelling them, nearly always the cause of the light(y)
17,575
42,958
there are a few regular faults
1 the wiring under a swivel seat damaged
2 the clock spring in the steering column snapped
3 the airbag ecu has failed
normally it is 1 or 2, but have heard of quite a few ecu fails
Dec 10, 2013
3,422
12,126
South Staffs
Pilote P740GJ
I might be talking a load of cobblers here but I think it is best to disconnect your battery before messing with airbag wiring.
Oct 8, 2016
221
224
bognor regis
Burstner Aviano 675G
10 years
They’re a pain in the neck those lights and an MOT failure, it can be the wiring under the seats, true. If not take it to an auto electrician, they can normally sort it as it’s so common on all vehicles.
17,575
42,958
always a wise move in case of any parasitic current causing the airbag to go off
Feb 16, 2013
19,687
51,832
uttoxeter
50 years
Don't think you need to go that far but make sure the ignition is off.
Jan 11, 2010
2,746
9,540
Chester
Auto-trail
Had that problem with ours, it was a faulty ECU, we were lucky Fiat paid for the replacement.
Jun 22, 2012
3,750
40,690
Sherborne Dorset
Same problem and it was the airbag ecu. We were told it meant that the airbag might deploy when you didn't want it to. Seems unlikely as that would be very dangerous and should make the van unsafe to drive in which case I shouldn't have been allowed to drive it 2 hours to Southampton to get it done under warranty. Seems more logical that with the fault it might NOT deploy. Having said all that I'm afraid it's all supposition from me who knows nothing about mechanics but just using logical thinking haha. Good luck but what a pain for you.
Oct 2, 2008
4,463
7,926
Salopia
Duro 6x6 Overlander
since 1968
@NickNic Is spot on they have to passive fail , and it doesn't mean that all the system will fail if the fault is just one item circuit unless single critical . When doing the underseat wiring check , it will need the ign off to be able to do the re check when you switch back on anyway . Don't just check the plugs are together , as they usually are, because double locked, its more likely the locating tang on the pin has been bent and allowed the cable to be partly pulled out of contact . So physically check the wire for movement . Airbags are harder to accidentally deploy than they used to be.
Oct 14, 2007
3,973
6,195
Rochester
Auto-Trail Mohawk
16 fun filled years
Airbag ECU sounds like the likeliest culprit, you will need a diagnostics check to be sure.
Candapack
Candapack
711
2,639
Fife, Scotland
what m/h is it £440 if ecu
It's a Rapido V55 PVC, on a Fiat Ducato, first regd Jan 2017 so should be still under warranty (2 years?).
The problem isn't getting it fixed, it's getting it fixed (or not) tomorrow.
Aug 31, 2009
147
156
Near Long Stratton, Norfolk
Carthago C line
25+ years
We had our airbag ECU fail at 1100 miles, and replaced under warranty. Unfortunately we had to wait 10 days for the new part to come from Italy! As already said the airbags will NOT deploy if there is a fault, the system is shut down until fixed.
Colin
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Connector under seat was the issue with both my Smart and the Punto. I now have a programme to reset the MIL and Airbag lights after I fix it. Saves a 40quid visit to the Garage each time!. Multiecuscan software runs under Windows for Fiats. The "free" version will not reset lights. But the 50quid upgrade will and was worth having (for me anyway). plus USB OBDII "dongle" off e-bay.
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Mine was ECU failure.. just over two years old....
Ten min job for them to replace.. and just over £200 If I recall...
I had to wait for part.. but as a F/t’r carried on regardless until fitted..
Candapack
Candapack
711
2,639
Fife, Scotland
Update, decided best to have it checked properly and delay travelling for, hopefully, a couple of days. Nearest Fiat Pro has slotted us in tomorrow evening (incredibly, the workshop runs from 7am until midnight), se we'll know what the problem is on Thursday and then decide what to do.
Thanks to all for your input.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Airbags make a big bang and a big mess so DO make sure you take OFF the battery lead first before delving in there.:eek:
17,575
42,958
and wait at least 5 minutes after disconnecting before touching the wiring for the airbag
