Air suspension (1 Viewer)
wadey250570
3
dont know
Air suspension has stopped working
The bags are ok and the air compressor Kd working it’s like there’s no power going to it when I turn ingnition on
Has anyone had same experience
Apr 9, 2018
8,597
44,200
Worcestershire
Bailey Adamo 75-4t
March 2018
:hiya2: w2f
What make of AS please?
Fuse?
Can you measure the 12v at the compressor terminals?
Does the engine run and have enough battery charge to run the compressor?
Just a few first thoughts
W
wadey250570
3
dont know
Sorry don’t know it’s on a Mercedes x ambulance
Apr 9, 2018
8,597
44,200
Worcestershire
Bailey Adamo 75-4t
March 2018
The maker may be on the compressor body.
I would start by checking if there is 12v at the compressor input terminals. If not, try a jump lead from a battery to the terminals to see if the compressor is working. If no 12v then you will need to trace back along the positive feed to check fuses and connections. Maybe also check that is has a good ground connection.
W
wadey250570
3
dont know
I’m thinking it could be this the red wire is live but the black wire isn’t
Trying to find a new one but can’t seem to find one
Nov 13, 2011
1,480
3,519
Lincolnshire
PVC
30 years
The red wire is live but the black wire isn't :rolleyes: :censored::giggle::(
Geoff
Feb 20, 2021
24
7
Sunder
NIESMANN &amp BISCHO
did you get sorted with your air compressor jute mine has stop working to
Steve and Denise
5,280
14,067
Spalding LINCS
A Class Carthago
Since 2008
When ours failed at 3 years old it was the pressure switch on the compressor got a new one from the Viair dealers in Derbyshire easy to change.
Apr 9, 2019
408
368
East Riding Of Yorkshire
30 years Caravan 13 years Motorhome
I was offered a wired in compressor and declined, stuck with the manual system which means I can use foot pump or electric pump, as on my 1st set of airsuspension. Never had a problem.
