???? I've just spent over 7k on full air for my van.Thanks for that some of the uk based kits were getting a bit scary price wise
It’s only 2 grand, go for it ????Air assistant suspension ... we had it on 2 coachbuilt MHs and would certainly recommend it ... ooooooooo ... that's just made me wonder if it's another extra we should consider fitting ot our new MH!
That'll be a no then! I forgot that the Al-Ko chassis ones are EXPENSIVE!!!It’s only 2 grand, go for it ????
Are you up plating your weight or just doing it for a better ride?On the fence with this have elddis autoquest 180 2008 alloy body, I can either uprate springs or go for air bags anyone have any experience with either pros and cons please I wont judge honest !!!?
Where would you put it if you couldn’t put it there? I couldn’t, I have all my vanbitz gubbins there!?I bought a kit supplied from these guys. Don't worry that they are not UK base as it arrived in less than a week and tracked all the way by DPD couriers. http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=163711136328 and the gauge mounting panel came from Marcle Leisure.
Here's the gauge panel and controls mounted just to the right of the steering column in our van.
That's only semi- air, full air on the rear is £4½kThat'll be a no then! I forgot that the Al-Ko chassis ones are EXPENSIVE!!!
Your in a different league now your on Al-ko ???That'll be a no then! I forgot that the Al-Ko chassis ones are EXPENSIVE!!!
Probably a stupid question but can you alter the ride height just momentarily to get you out of a fix? (just dug my towbar in the tarmac going up the ramp into the MOT garage)On my system it is one air compressor that feeds a tee piece which feeds both sides at the same time. The tee piece contains non return valves.
If you have the compressor fitted, yes. Compressor is about £300.Probably a stupid question but can you alter the ride height just momentarily to get you out of a fix? (just dug my towbar in the tarmac going up the ramp into the MOT garage)
Thanks Andy, that would have got me out of trouble today!! Bit of a bugger tho, all my lovely vanbitz goodies are there tho, I would have to do some modding!!i can raise the rear of mine by about 4”, just by altering the pressure with the dash controls. It’s been useful many times.
Same system can be fitted in many places as shown above ????Thanks Andy, that would have got me out of trouble today!! Bit of a bugger tho, all my lovely vanbitz goodies are there tho, I would have to do some modding!!
Food for thought, thanks?
