I have a very slow leak on the Dunlop air suspension fitted to our van. It is from one of the connectors in the air line from the gauge to the bellows. There is lots of spare tubing so I should be able to just remove it, clean and refit. Are the connectors easy to push on -is a bit of grease required? @Trout bum -I think you have recently fitted the system?
I know that you are not meant to run the system below 0.5 bar but I presume that I needn't worry about it being at atmospheric pressure whilst I do the work?
Just to clarify the leaking connection is the white one in the black tubing:
