Air in water system/Pump? (2 Viewers)
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
To avoid the risk of frost damage I drained down the water system but as I am going away tomorrow I have refilled the system. Despite the pump running there is no water flowing from the taps. Having read the manual it seems this could be due to air in the system/ pump. So after removing the shower head and opening the tap and turning off the pump I blew and sucked until I found water. Despite this the pump continued to run but no water flowed.
I have had this problem before when we ran out of water and after a couple of days driving the system corrected itself and worked properly until it was drained down. The manual suggests to release air in the pump the pump should be given a good shaking whilst submerged in the tank. A great help when there is no advice as to how to access the freshwater tank!!!!
My conclusion is air in the pump could one of you clever folk confirm this please?
Also as it is this much trouble to refill after draining down I am seriously thinking of not draining down the system but leaving it filled with a low wattage heater on to prevent the pipes freezing up. The Truma boiler will automatically dump when temperature reaches 6 degrees and as long as the tank is not completely filled it is unlikely it will freeze solid and cause damage as their will be room for expansion, I also have a "heater" fitted to both tanks as part of a winterisation package. (My mh stands on the drive and is connected to mains)
I have read all the threads about this and am convinced the right thing to do is to drain down, but as I intend to use the mh at least once a month over the winter period I could do without all this hassle.
Bobndebs McKay
164
2,890
Bali for the Winter!! Back in Feb 2016
Hobby 750 FMSE
5 months travelling Through France, Spain, Portugal, Germany and Holland as a Full timer in our firs
You could try priming the system by removing the shower head, holding the hose high and pouring water down it until the whole line is full, then while still holding the hose up, run the pump and see if that primes it and bleeds the air out. I am given to understand that most pumps are self priming nowadays, but a bleed point in the line would be useful!! Good luck and please let us know for my own future reference how you get on.
Sep 25, 2009
793
1,386
south yorkshire
since 2004. Tugger 10 years on and off
Don't know how long you are trying to prime pump.but mine takes a good 5 minuites to get the water flowing properly.:whistle:I close all taps .then open one tap closest to pump.then when water runs freely slowly open hot tap to get rid of air in boiler. Then do same with other taps. I personaly would not leave water in tank if it looks like being realy cold.I don't think its the tank you have to worry about but the taps can split on some models.(y)
Theonlysue
6,104
7,383
As Executive 50th an
Not long enough!
I have had an airlock once, so I drained all the water out and started agsin.
my handbook says to open hot tap furthest from fresh water tank till water comes through. This may take a while as the hot tank holds approx 10 litres, so that is 10 litres if air that had to come out. You should feel the air coming out of the tap. Then close that and open the hot tap that is next furtherest away and work in that order. Then repeat with cold water tap.
I empty and refill as required, as any ice damage could be expensive to repair.
Good luck :)
normanandsue
normanandsue
1,871
21,571
van conversion
Thanks Mike I will give it a try. Should I keep the pump running whilst I wait for the air to come through? My handbook warns of the danger of running the pump without water (I presume an air lock in the pump would mean the pump running "dry"?)
normanandsue
normanandsue
1,871
21,571
van conversion
Have tried running pump for 5 minutes with cold tap open; have tried running pump for 5 minutes with hot tap open. Still no water.
Ran pump, opened sink tap and opened shower tap took off shower head and blew down pipe and air came out of sink tap, but no water.
I am concerned that running the pump with no water coming through will ultimately damage the pump.
Badknee
7,407
412,678
notloB
Vantage Neo
Living the dream.
Stick a hosepipe on the shower hose and see if you can get some water into the tank that way, if it arrives in the tank the pump must be full. (y)
MikeD
3,936
3,697
London
IH PVC
If it takes so long to prime the system then you must be sucking air into the water supply to the pump.
My Autotrail also took a long time to prime and the dealer found out that the supply pipe into the water tank had a air hole (the centre of a pop rivet) in the feed line.
I understand that a self tapper into the centre of the pop rivet cured the problem.
But in my humble opinion if it takes so long to prime you must be sucking some air from somewhere or your pump is not sucking at all. (y)
Feb 8, 2014
1,662
4,673
Sheffield
Eldis Majestic 115
Vans and tugs since mid 70's
I had the same problem earlier this year, I had opened the hot taps pror to filling but made the big mistake of forgetting to turn the pump on. Eventually had to dump the water and refilled properly without problem.
Sep 25, 2009
793
1,386
south yorkshire
I don't know how old your pump is.My pump is a surflow.I had a similar problem,Turned out to be the diaphragm in pump.It cost aprox 18 pounds for parts.Its a easy repair.If you Google it you will find some info.
Wickolad
490
542
Wickersley
I know this suggestion may appear totally unrelated but I think in principle should achieve same result.
Having had my previous domestic central heating system drained down at home, the pump could not get rid of an airlock when trying to refill. The plumber connected the garden hosepipe to the downstairs radiator and used mains pressure water to push out the airlock by opening the bleed screws in the all radiators and it was successful.
Using this principle, could you not open all taps in hot/cold positions including shower. Then using garden hose on relatively low tap setting so as not applying excessive pressure, and rubber bung of sorts to form a decent seal at the water filling point force water into the tank, (you may have to temp block the overflow pipe) thereby forcing water throughout the hot/cold pipe system including pump and driving out the airlock.
If you then get water through all taps and still the pump doesn't do what it should, then this may point to the diaphragm as previously mentioned.
It is almost as was suggested with the shower hose but using mains pressure to expel the airlock. Main thing is to not have garden hose tap set too high, I think.
Hope this does the trick for you.
Lance.
Wickolad
490
542
Wickersley
Just an afterthought as well, only because I've actually done this myself but I'm not in anyway suggesting you may be nearly as daft as what I felt at the time. Did you remember to close the water dump valve for your heater system. When I dump mine to drain the system I always leave it open in case of anteater left in freezing, it allows expansion and no pressure fractures to pipes or fittings. I have forgotten to close this a couple of occasions and wondered why the water wasn't coming through the taps when I came to refill the system. I doubt I'm the only one to have ever done this though.
Lance
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
Is the pump submerged in the tank or an external one, reading your first post I assume the former.
If the pump is running dry I would limit the time it is on which you indicate is what you have been doing.
golly
2,005
69,615
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
Lance
Why do you keep anteaters in the fridge? Do the RSPCA know about this :roflmto:
Bobndebs McKay
164
2,890
Hobby 750 FMSE
If its a vane pump then there will not be a diaphragm to worry about! I would establish the type of pump you have, position etc and then as Wickolad suggests look at dump valve etc. Let us know how it goes! Good Luck
Wickolad
490
542
Wickersley
Hahaha, well spotted. Pre- emptive text. Isn't it just great. Teach me to check before posting.
Can't get away with anything on here haha.
normanandsue
normanandsue
1,871
21,571
van conversion
What I might have done wrong!!!!!!!!!:(
  • I switched the pump on whilst filling the tank
  • I left the taps open having failed to close them after draining the tank
I have drained the tank and am now refilling it with pump off and taps closed.
I will let you know what happens.
If the problem persists then it seems as if sucking on the shower hose with pump on and tap open is the only solution.
Have never had a Whale system before and never had these problems either
normanandsue
normanandsue
1,871
21,571
van conversion
After 15 minutes of sucking and blowing I manage about a couple of mouthfuls of water but none flowing from the taps.
It does seem as if the air is in the pump which the manual says can be shaken for it to be expelled but as my Freshwater tank is a sealed unit that is not going to be possible. I had this problem once before and after a couple of days it sorted itself, so I am hoping after our outing today that might happen again.
I will never buy a mh with a whale water system again :devil::devil::devil:
jonandshell
5,476
8,299
Not got one!
Always prime the hot water side first!
The boiler needs to be filled before you will see any thing at the taps!
Some pumps create more flow than others, so be prepared for a wait.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
Mine is a submerged pump in tank under the lounge sofa. When refilling, sometimes it don't run. I have to reach in to tank, tap the pump against wall of tank. It splutters and runs.....
ojibway
531
305
Eastbourne
since 2005
I'm surprised the tank is sealed. It would make it impossible to replace the pump in the event it failed. Maybe it's an 'in line' pump?
The pump manufacturers say you should not run the pump 'dry' for too long.
I have replaced my immersion pump several times, first time because it would stop pumping water when water level was low - due to air getting into the pump - a real pain having to get at it and, yes, wiggle it.
I use a Whale pump now (self priming) and have no problems. It does not matter what tap you open as the pump is 'pushing' water from source and will push where ever a tap is open, so, if you want to fill the hot water tank then you open any hot water tap. Whichever tap you open the pump should prime. You will know if it is pumping dry as the motor will run much faster (whine). When it is primed it will sound more laboured in which case, if water is not coming through then you have a constriction or it's pumping out somewhere else - a leak or pipe disconnected?
Hope you sort it!;)
gozomike
Funster Life Member
1,001
863
Since August 2008
Hi Norman
I wonder if it would be worth getting a normal external pump fitted, it looks as if you may have this problem quite frequently.
Mike
11,842
14,071
I used to worry about letting the pump run for extended periods. A year ago I opened the drain tap but forgot to turn off the pump. Returned after 2 weeks to find the pump still running, no problems with the pump.
normanandsue
normanandsue
1,871
21,571
van conversion
As I hoped the air freed itself and all taps worked perfectly and we had a great day/night in the Borders the fireworks were great and a return journey through Jedburgh via Kelso was pleasant despite the intermittent rain.
normanandsue
normanandsue
1,871
21,571
van conversion
I emptied the tank after initially and then refilled it. I spent 5 minutes sucking and blowing down the shower hose. After this nothing, we just set off prepared to make do with bottled water; as we were on electric hook up we did not necessarily need hot water, but when we arrived the air lock had gone and everything worked fine.
