AIR IN WATER PUMP
Midlands
IH 630 FL
Hi,
I have an IH 630 RL, but am having a problem with air in the water pump, it splurts out the water when turning hot or cold tap on in kitchen area or bathroom, it seems like air is in pipes but I cannot seem to get rid of it, any ideas please. its a Truma combi 4 heating system.
Check the filter just before the pump, they often get a hairline crack in the winter then the pump draws in air from it whilst in use, and often doesn’t show a leak.
May need to let it run longer ..open all taps and just let it blast for a while ..after a couple of minutes if it's still blasting out air there is probably a loose fitting or as said crack in the filter.
