- May 2, 2019
- 106
- 120
Looking at having roof mounted air con installed does anyone have experience of dometic fresh jet 2200 ?
They are definitely not quiet. When in warmer climes (I wish) will have it on to cool the interior whilst we are sitting outside so nice and cool when it's bedtimeA LOT noiser than we were expecting when we had one on a rental van we used. Not just that but the way they kick in and out is also kind of annoying.
Our ducted is very quiet compared to roof mountedThey are definitely not quiet. When in warmer climes (I wish) will have it on to cool the interior whilst we are sitting outside so nice and cool when it's bedtime
I have the Truma Aventa Compact plus which has 2200 watts of cooling powerThanks I’ll have a read up on the truma
You can but it wont work very well, the cooled air should be as near the roof as possible, the cool air will sink, if you don't do this you will end up with nice cold feet and a hot head! this is the problem with this type, how to route the ducting discreetlyCan I just simply tee into the heating ducting ? If so all the hard work is already done
I intend to do a bit more research into this before I commit to anything however the ducted version is starting to look a bit more attractiveWe have a Dometic 2200 on our van.
I would echo they are noisy and the compressor does cut in and out.
It takes quite a long time to make a big difference.
I understand they cannot be regassed (Dometic anyway)
It’s worth noting we use the heating function quite a lot early in the morning to take the chill off.
They can be regassed needs to have a port fitted but no problem.We have a Dometic 2200 on our van.
Is it roof mounted or ducted? I have a Delaware, so if it cools your Comanche it will work for us.We also have the Truma Aventa which also has an heater built in, it has a night mode as well so can be left on if we wish
It can cool our 8.8 mtr moho perfectly well even in 40dgs + as it was in France 2019
Phew!!
Highly recommended and if you can’t sleep then you’ve not drank enough vino
it’s roof mounted and took around 40 mins to fit.Is it roof mounted or ducted? I have a Delaware, so if it cools your Comanche it will work for us.
We have the dometic fresh light fitted on our Delaware we think it's great when in EuropeIs it roof mounted or ducted? I have a Delaware, so if it cools your Comanche it will work for us.
I will try and find my post where I installed oursNever considered the ducted option but will read up on that also
ThanksI will try and find my post where I installed ours
Thanks really helpfulit’s roof mounted and took around 40 mins to fit.
Remove the ekki in the kitchen area, fit the aircon unit and torque it down, no need for any sealant btw, we fitted a switched supply and no cables are seen anywhere and voila
It really is very easy to do and well worth it imho. Also if i sell the moho it can be removed and the ekki refitted
the night mode, if needed is also good, we cool the van down before going to bed then turn it to night mode, this then runs all night on/off f you want it to
Truma have/had a promotion on atm and fitted it was £1800, I used Auto Additions btw who was superb and you’d think it was fitted at the factory as he left no trace of anything being done, highly recommend him
Al
