i bought my 2nd hand van 2 years ago as a private sale and the air con didn’t work. Hmmm...must need re-gassing i thought, so i did that. Worked initially but failed again when i actually needed it 12 months later.
There must be more to this problem, i thought, so i took it to Adams Morey, a large reputable firm with garages across the south. They had it for 2 weeks, tried re-gassing it and that didn’t work, tried diagnostics but couldn’t find a problem, tried a dye test and had a think. They decided that the condenser needed to be replaced as well as the pipe connected to it...so that cost £800.
You can see where this is head can’t you? It worked for one trip and has now packed up again.
Do you have any idea what the problem might actually be please? Also, as a customer of Adams Morey, do you think there is any comeback at all? They did the diagnostics - is there no kind of 'warranty' etc for the work they do?
i guess the obvious answer is 'phone up and politely ask' which i will be doing on Monday, but I'd like to know what rights i have as a customer (if any) if their response is basically 'tough luck, get your wallet out again'
thanks Russ
thanks Russ
