Wissel
Hey all, need a little help
I have a new headunit to replace the dated factory one and wonder if I need anything else to make the steering wheel controls work with it?
My steering wheel controls just do the volume and change the radio station.
The headunit I've gone with is a Sony DSX-A416BT which is a radio with dual Bluetooth connections, meaning I can use my tablet as satnav and my phone for calls. It also comes with an external mic which I figured would be good in a van. The remote function is controlled via a 3.5mm jack.
I bought this last August and just getting around to fitting it, so had a quick read of the fitting bumf. It says this, regarding the steering wheel controls:
I guess this means I need to purchase a separate adaptor?
I'm sure plenty of people here have replaced the headunit. Did you need an adaptor? If so, what would be best?
Thanks, David
Steering wheel control compatible
The DSX-A416BT can also be paired with your steering wheel remote. Special adaptors are vehicle specific.
Thanks, David
