sparky
Hi anybody tow a citreon Picasso on a aframe any probs or advice thinking of buying one
You need to check what you can tow by checking your trainweight.
Will that not cut down your pay loadTrain weight 6000kg Picasso train weight 1420 kg
Sorry, you need to subscribe to see this content. Subs are £20 a year. You Can Subscribe Here
Log in or register now.Is that because you don’t sell themI read that A frames are illegal!Sorry, you need to subscribe to see this content. Subs are £20 a year. You Can Subscribe Here
No. An A frame presents no nose weight to speak of.Will that not cut down your pay load
But it will reduce the amount of payload in the MH as the total of both vehicles cannot exceed the train weight: 6000kg less Picasso 1420kg = 4580, less the weight of the A-frame ... as the MH has had it's MAM increased to 4500kg and most of the additional payload is used up it could be a bit of close thing! Personally I wouldn't want to tow anything as heavy as a Picasso.No. An A frame presents no nose weight to speak of.
Surely the two things are separate? You cannot eat into the MAM by exceeding the towing limit of Train Weight minus MAM = 6000 - 4500 = 1500. Conversely you cannot load the van past 4500 by reducing the trailer load. Or are we saying the same thing in different ways?But it will reduce the amount of payload in the MH as the total of both vehicles cannot exceed the train weight: 6000kg less Picasso 1420kg = 4580, less the weight of the A-frame ... as the MH has had it's MAM increased to 4500kg and most of the additional payload is used up it could be a bit of close thing! Personally I wouldn't want to tow anything as heavy as a Picasso.
Probably!Surely the two things are separate? You cannot eat into the MAM by exceeding the towing limit of Train Weight minus MAM = 6000 - 4500 = 1500. Conversely you cannot load the van past 4500 by reducing the trailer load. Or are we saying the same thing in different ways?
Agree about the A frame. I weigh mine with the trailer attached so nose weight is taken into account but don't weigh the trailer itself as it's well under the towing limit. I'd do the same with a toad.Probably!
I believe that some A-frames can be quite heavy and the stated weight of the Picasso might not include a full fuel tank etc, so for example if the Picasso with the A-frame and everything in it comes to 1600 that would mean the payload of the MH would be reduced to 4400, if the MH is normally at or just under 4500 that would cause an issue ...
That's what I thought I said.No, this is a common misconception - there isn’t a plated towing limit only a GVW and GTW. You would not be taken to task for towing something that exceeded MTW minus MGW provided that you exceeded neither the GTW nor the GVW.
See info on .GOV website here:
Towing with a car
Towing trailers, caravans and horseboxes with a car, including the weight and size limits, and what licence you need to havewww.gov.uk
Ian
